ippo1236 opened this issue on Apr 04, 2023 ยท 13 posts
ippo1236 posted Tue, 04 April 2023 at 6:49 PM
Hi guys, I'm new to Poser 12 and I've been trying to learn it. I've been trying to play around with some settings and some of my own research on the internet. I'm trying to find out how I can increase render quality on Mac, if that's even possible. I'm on a macbook air. I can't do as much as I'd like to with the program given my technology, but I'd like to push it to whatever the ceiling may be.
Additionally, I'm just curious on a few things. What determines max render quality? Is it the graphics card of a computer? Do you guys have any recommendations for powerful laptops that work well with Poser and produce good quality renders?
Thanks and I'm sorry if this is a dumb question.
ThunderStone posted Tue, 04 April 2023 at 7:40 PM
Hi, ippo1236. No questions are dumb. Okay? I'm on Windows not a Mac. If you want to find out about the specs needed to run p12, stop by posersoftware.com and read up what's the minimum requirement for running software on Mac or Apple computer.
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Richard60 posted Tue, 04 April 2023 at 8:25 PM
Render quality is determined by how much processing time vs. power is applied to the image. That power comes in many forms. A powerful graphics card with CUDA can speed up a render a lot. More cores/threads a CPU has can speed up a render. If nothing else more time will result in a better render.
ippo1236 posted Tue, 04 April 2023 at 8:44 PM
More time as in more experience?Render quality is determined by how much processing time vs. power is applied to the image. That power comes in many forms. A powerful graphics card with CUDA can speed up a render a lot. More cores/threads a CPU has can speed up a render. If nothing else more time will result in a better render.
Richard60 posted Tue, 04 April 2023 at 9:09 PM
No more time as in a render can be 10 minutes or 60 minutes.
ippo1236 posted Tue, 04 April 2023 at 9:32 PM
So without better hardware, there isn't much I can do to improve quality?No more time as in a render can be 10 minutes or 60 minutes.
Rhia474 posted Tue, 04 April 2023 at 9:44 PM Online Now!
ippo1236 posted Tue, 04 April 2023 at 9:48 PM
That is not true, you will just spend more time rendering. Are you using Firefly or Superfly when you render? I can suggest some settings to try.I am using superfly. I am open to try whatever settings, thanks a lot.
Rhia474 posted Tue, 04 April 2023 at 10:33 PM Online Now!
Will be a bit, I am not back at my render compy until later tomorrow.
RedPhantom posted Wed, 05 April 2023 at 8:52 AM Site Admin
I found these settings worked well on my old computer for most images. I don't know what kind of specs a MacBook air has. But I figure it probably is better than something that might have been mid-ranged in 2012.
Y-Phil posted Wed, 05 April 2023 at 9:51 AM
And don't forget that it means 10x10=100 diffuse samples, 100 glossy samples, 20 transmission samples, etc...
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
Rhia474 posted Wed, 05 April 2023 at 5:04 PM Online Now!
Okay, here is one that I generally get very good results with in Superfly with my not-very-new machine. Disclaimer: I am on a Windows box, not a Mac, so I have no claims for any of this being suitable for what you have, but it will give you an idea.
If your machine chokes on that, try the below draft and see how that looks. Then experiment with the in-betweens.
NikKelly posted Tue, 11 April 2023 at 6:27 AM
I'm several generations behind such uber-tech but, IMHO, 'superfly, progressive' seems to thrive on pixel-sample count: The more, the faster.
Lots of light helps, too...
I do test-renders with 14 pixel-samples, WIPs with 32, 'nice' with 64, 'good' with 96 and 'over-kill' with eg 256, run overnight.
Until my ageing twin GPU cards max-out on scene complexity, they like 1024 vols+buckets. I can push them a lot further by reducing via 256, 128 to 64. My CAD-Tower's CPU cores and network-render 'Box' also take that 64...
