Forum: Poser 13
Subject: Scenes render black
Rhia474 opened this issue on Apr 07, 2023 ยท 38 posts
Rhia474 posted Fri, 07 April 2023 at 1:08 PM
All of a sudden all my Poser 13 renders come out black; it started yesterday. It shows progressive rendering fine and when I either stop the render or finish, the window turns to complete black.
I checked error messages; this is the latest one:
13:04:03 - Analytics: Recording event for Size:1404x780
13:04:03 - Analytics: Starting timer for Render:SuperFly
13:04:06 - SuperFly: Start rendering on device NVIDIA GeForce GTX 970 (Display).
13:04:51 - Warning: Error Rendering in SuperFly.
13:04:51 - SuperFly: OPTIX_ERROR_INVALID_VALUE in optixLaunch(pipeline, cuda_stream_, launch_params_ptr, optix_device->launch_params.data_elements, &sbt_params, work_size, 1, 1) (c:hudsonbuildsworkspaceposer_master_wincodecyclessrcdeviceoptixqueue.cpp:190)
13:04:51 - SuperFly: Rendering time: 45.15 seconds.
13:04:51 - SuperFly: Rendering memory: 7199 MB.
13:04:54 - Analytics: Ending timer for Render:SuperFly
Rhia474 posted Fri, 07 April 2023 at 1:09 PM
Above error was for OptiX. here is what I get as anerror with GPU:
13:08:39 - Warning: Error Rendering in SuperFly.
13:08:39 - SuperFly: Illegal address in CUDA queue copy_from_device (integrator_shade_surface integrator_sorted_paths_array prefix_sum)
13:08:39 - SuperFly: Rendering time: 22.44 seconds.
13:08:39 - SuperFly: Rendering memory: 7153 MB.
13:08:42 - Analytics: Ending timer for Render:SuperFly
Y-Phil posted Fri, 07 April 2023 at 2:09 PM
Have you tried to reboot the PC? (not turn off/on: restart)
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
nerd posted Fri, 07 April 2023 at 3:05 PM Forum Moderator
The GTX 970 does work. I have 2 of them. It's possible there's something in that scene it doesn't like. First try rendering one of the included scene. That will eliminate some kind of hardware issue.
If a simple scene renders but not the scene you're having problems with it could be there's a material setup in that scene that's making the GPU unhappy. If this is the case we'd like to get that scene in the support system so we can track down the exact issue.
If it's just the one scene, go to https://support.posersoftware.com/ and create a support ticket. Use Poser 13's scene export (File > Export > Save for sharing ... ) that will create a scene complete zip file that can be attached to the ticket. If it's too big to attach we can provide an upload link for your scene. We can use that ti try and isolate the problem.
Y-Phil posted Fri, 07 April 2023 at 3:13 PM
Oh that reminds me of a candle in a scene, with a bad topology it had the same effects, indeed.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Rhia474 posted Fri, 07 April 2023 at 3:41 PM
Well, one of the included Bedroom scenes renders *grey* with the exact same settings. I am somewhat stumped and a bit irritated. Do you have a suggested scene I try from the Included content? Right now not a single anything I tried worked today.
Rhia474 posted Fri, 07 April 2023 at 3:53 PM
Nothing renders with OptiX or graphics card. The only way I can get anything to work right now is with direct CPU rendering and even that is a hit and miss--some scenes render but grainy like I was an absolute noob at this, or greyed out). Was there an update? Do I need to reinstall?
DCArt posted Fri, 07 April 2023 at 4:06 PM
Rhia, which bedroom set are you trying to render?  I can try it here
Rhia474 posted Fri, 07 April 2023 at 4:18 PM
Interior Sets --> MA Bedroom
Checked and updated graphics drivers as well.
DCArt posted Fri, 07 April 2023 at 4:21 PM
OK I will try that here and see if I can figure out what's going on
Rhia474 posted Fri, 07 April 2023 at 4:25 PM
You guys are super kind, this is very mysterious.
DCArt posted Fri, 07 April 2023 at 4:30 PM
We try 8-)  You are super kind too. We got your back 8-)
Y-Phil posted Fri, 07 April 2023 at 4:32 PM
The superfly version in the included items computes correctly on my system, but I have to say that Poser13 claimed that there was an update today, and I have no details as the version remains 13.0.287
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
DCArt posted Fri, 07 April 2023 at 4:33 PM
Ouch. Well I did the preload of the MA Bedroom and it rendered fine. So now we have a REAL mystery.  But hopefully since Nerd has the same video card as you he can reproduce it.
AmbientShade posted Fri, 07 April 2023 at 4:39 PM
I've had the same black render phenomenon a few times, along with random body parts turning black or light purple, and I use CPU rendering which is currently a ryzen 7 on win10. I have a gtx 970 as well but it hasn't rendered anything from Poser since the SM days of P11. It hangs up and does nothing so I have to force close or Poser crashes completely so I just have stuck to cpu rendering ever since cause I can't afford an upgrade and I don't want to stress my ancient card or I'll be out completely lol.
I haven't checked the error messages but if it happens again I will.
Re-rendering randomly fixes the problem, or I'll click a setting on the affected material and that seems to fix it. Sometimes re-importing the image texture has fixed it. Just reloading textures does nothing.
DCArt posted Fri, 07 April 2023 at 4:42 PM
I'm going to go through the shaders on that stuff and see if anything looks suspicious.
Rhia474 posted Fri, 07 April 2023 at 4:50 PM
Hm, here is a thing:  I had render going fine for a bit, then I toggled Post-render FX and that caused black render no matter what I tried. I am re-rendering without post-effect to see if toggling that causes it and if I have to completely close Poser, reload scene and render again to fix.
If that's what it is, the post-effect selections may be buggy.
DCArt posted Fri, 07 April 2023 at 4:54 PM
Let me know how that goes, I have a couple other things you can try if you still have issues.
blackbonner posted Fri, 07 April 2023 at 4:58 PM
I think the key to this issue could be the usage of the PostFX.
Rhia474 mentioned that the render turned black after the render is finished or after the canceling of the render.
This sounds like the PostFX is on and working, right?
This happened to me a few days ago and it was a negative value setting for exposure.
I also had some difficulties to get rid of the setting, it jumped back to the negative numbers after closing the PostFX dialog.
To fix this I had to set a positive number and use one or both save options in the dialog.
Hope this helps.
Y-Phil posted Fri, 07 April 2023 at 5:09 PM
Exposure = -1 means black result, at least on my PC but I suppose that with -1 it should be correct, shouldn't it?
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
DCArt posted Fri, 07 April 2023 at 5:14 PM
OK. Try this:
From the Launcher, choose Empty Scene.
Choose Props > Interior Sets > MA Bedroom > !!!Preload.  That will load the entire scene.
Choose Lights > INterior Sets > MA Bedroom > MABedroom_SuperFly lights
Choose Cameras > Interior Sets > MA Bedroom > Camera 4.
Set your Optix render settings.  Quality doesn't matter because we are testing PostFX.  Just let the render finish (if it can)
After the render is done, a thumbnail should appear at the top of the recent renders palette.
Right-click on the thumb and choose Edit Post Effects.
Check Apply Intel Denoise and enable Bloom.
Does that work for you?
RedPhantom posted Fri, 07 April 2023 at 5:26 PM Site Admin
I'm going to add to the confusion here.
I got the same error message as Rhia's second with an RTX 2060 when I tried to do a scene with a fog cube and an image on the background shader
DCArt posted Fri, 07 April 2023 at 5:29 PM
@RedPhantom if you still have that scene handy, zip it up as Nerd instructed above and attach the scene to a support ticket
Rhia474 posted Fri, 07 April 2023 at 5:44 PM
I will try as soon as my back at my computer. Thanks y'all!!
nerd posted Fri, 07 April 2023 at 6:31 PM Forum Moderator
The exposure set to -1 is my bad. Some of the default scenes and the factory scene got shipped with the Post FX exposure set to -1. That will be fixed with the first service release. So change those to 0. Zero is no change in exposure and was supposed to be the default value.
Rhia474 posted Fri, 07 April 2023 at 8:41 PM
@DCArt: holy moly, yup, that worked. Look!
@nerd, glad we nailed this one down!!
hmatienzo posted Sat, 08 April 2023 at 12:07 AM
I have to say, this is starting to irritate me!  Quite a few of the models render all black for me and I do not use postfx.  In Firefly I can almost bet it will be black, while in Super, the scene is a light blue screen.
L'ultima fòrza è nella morte.
hornet3d posted Sat, 08 April 2023 at 2:19 AM
I looks as though some of the older content in my runtime is going to have to be used with care.  I have an aging GTX 1080i graphics card which I found to to my utter disappointment would not work with Poser 11 but thankfully did with Poser 12.  It has been working fine with Poser 13 but today I tried to render a scene with a lot of old content but all I got was a grey screen.  Looking at the logs I am getting a Cuda warning similar to the one already shown here.  The scene will render using the CPU but there is still a slight issue with some old content in that I find glass looks as though I has been set up for emissions, I have seen this on content created by three different vendors so far.
I don't really blame Poser 13 for this as, despite all the efforts made to make it backwards compatible, there is bound to be a limit somewhere.  I think that using textures from old content will continue to be an issue as we move forward.   I thought the glass problem was due to a cellular node plugged into the defuse colour with a setting of 2+ on the diffuse but changing this alone does not sort the problem as both the specular and reflection needs to be looked at.  I now use a PhysicalSurface node to correct the problem.
Y-Phil posted Sat, 08 April 2023 at 7:12 AM
Be careful with old scene: they often have ambient occlusion. Till Poser12, the presence of this node used to make the render turn black.
I haven't tested this aspect with Poser13 because since 2019 I use one of the scripts provided with Sasha: it deletes all these nodes in one shot, and it's something I'm launching it systematically
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Rhia474 posted Sat, 08 April 2023 at 10:36 AM
It looks like all older content material will need to be reworked for P13 then. A pain, but at least we have GoPhysical to help with it.
Rhia474 posted Sat, 08 April 2023 at 10:50 AM
Can confirm: CUDA illegal address error persists with older content if trying to render older content with OptiX or GPU. Can only use CPU. Does not seem to matter is I reworked the materials with script to Physical Surface. There is some sort of reaction between the render engine using the GPU or OptiX that makes renders error out.
Should I add this as a bug to look into, or will this be an unfortunate feature or progress?
RAMWorks posted Sat, 08 April 2023 at 12:25 PM
Add it to the bug Rae!  :-)
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
JoePublic posted Sat, 08 April 2023 at 1:08 PM
Same here...
I tried a few of the supplied Poser 13 scenes.
They render fine in Firefly as well as CPU/Superfly, but are 100% black with GPU/Superfly.
ACER Nitro 5, Windows 10, 32.0 GB RAM, GTX 1650, i7-10750H CPU
Doesn't really bother me that much, as I'm sticking with Firefly for now, at least I until I have a proper GTR card.
And you can't expect a completely different render engine to work with a shader it doesn't understand, anyway.
(Although I noticed that some of my "optimized" Firefly skin shaders render nicely even with GPU/Superfly after some minimal modifications.)
Even the preview still looks "nice", too. (Unlike the "pure-breed" Superfly shaders that just show up white in OGL.)
So there might actually be a type of "hybrid" skin shader possible that works with both engines with none or just little modifications?
RAMWorks posted Sat, 08 April 2023 at 1:48 PM
Just successfully rendered a really old scene from DM "Moon Cult" and it renders fine in both FF and SF.  This is the SF render.  This set is set up for Poser 6/7 so pretty old.
My Store is HERE
Rhia474 posted Sat, 08 April 2023 at 2:01 PM
Right, the issue is with specifically GPU and OptiX renders. Did you use those or CPU?
RAMWorks posted Sat, 08 April 2023 at 2:17 PM
Silly me, didn't look.
Now that I've converted using the Go Physical though the flames for the candle flames are all rendering like blocks/  Transmaps are all connected so it's another weird moment!  LOL
My Store is HERE
Rhia474 posted Sat, 08 April 2023 at 2:20 PM
Yeah, sorry, methodical me is methodical, lol. :)
hornet3d posted Sat, 08 April 2023 at 3:41 PM
RAMWorks posted at 2:17 PM Sat, 8 April 2023 - #4461332
For the flames you need to play with the transparent settings at the top of the PhysicalSurface, set the transparency 'GO Physical' usually leaves this set to zero.  Set the Emission strength to something above 0.000 to make the flames glow.  You may need to toggle the TransparencyMode from Opacity to Transparent but it seems to depend on the nature of the map you have plugged into color.
