peter_wade opened this issue on Apr 13, 2023 ยท 21 posts
peter_wade posted Thu, 13 April 2023 at 2:17 PM
I am trying to setup the Superfly skin shader described in another thread here but when I try to add the nodes I can't find the Redfilter or Bump2Normal nodes anywhere in any of the menus or sub-menus. Do I need an add-on to get these or am I doing it wrong?
Also, I can't find a Color Map or Bump Map node but I can find an image_map node. Is this the same thing?
Y-Phil posted Thu, 13 April 2023 at 2:24 PM
The redfilter is in fact this one (right-clilck)
Bump to Normal:
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
Rhia474 posted Thu, 13 April 2023 at 2:26 PM
They are renamed nodes to make sense, I gad to ask as well. Thanks for the details, YPhil!!
Y-Phil posted Thu, 13 April 2023 at 2:30 PM
Color Map and Bump Map are just simple Image node. You have two: the classic:
And the Cycles-based:
The difference between the two are some parameters available in the Cycles version and not in the other. At the beginning, the classic one is easier to use.
You can change the label of a node by simply double-clicking on its title, so that you may enter what you want:
Abuse of Cycles nodes, not Double BigMac's...
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Afrodite-Ohki posted Thu, 13 April 2023 at 4:18 PM
Wow, Y-Phil, I guess someone was hungry when explaining stuff ๐คฃ
Feel free to call me Ohki!
Y-Phil posted Thu, 13 April 2023 at 4:54 PM
Afrodite-Ohki posted at 4:18 PM Thu, 13 April 2023 - #4462090
Lol...Wow, Y-Phil, I guess someone was hungry when explaining stuff ๐คฃ
I saw the word Beginner so I thought that snapshot would be easier to understand, and I do love use Flameshot for this...
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
peter_wade posted Thu, 13 April 2023 at 6:41 PM
Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
One minor problem. I click on Subsurface Radius, update the numbers as shown and press return, but if I click on it again to check the numbers they have gone back to how they were at the start. I've tried not pressing return but clicking somewhere else but it still ignores my changes. Is there some trick to updating this?
hborre posted Thu, 13 April 2023 at 7:41 PM
Return sets the values. Those values are just starters that work well for SSS. There are other parameters that will give different skin tones, especially when the light shines behind the character through the thinner mesh illustrated below.
ghostship2 posted Thu, 13 April 2023 at 9:43 PM
my bad for re-using those re-named nodes.
ChromeStar posted Thu, 13 April 2023 at 10:53 PM
Make sure you are entering all three values separated by commas before pressing enter. If you try to enter a single value, it won't know what to do with it and might throw it away.Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
Y-Phil posted Fri, 14 April 2023 at 3:24 AM
Oops sorry I didn't get your joke correctly as I was tired. I don't why I'm using this all the time, I probably eat one each 5 or 10 years...Wow, Y-Phil, I guess someone was hungry when explaining stuff ๐คฃ
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Thalek posted Fri, 14 April 2023 at 10:34 AM
Y-Phil posted at 3:24 AM Fri, 14 April 2023 - #4462135
Because using Monty Python references in Python tutorials was already taken?Afrodite-Ohki posted at 4:18 PM Thu, 13 April 2023 - #4462090
You wanted to give them a fast response, filled with information?
You wanted to get to the meat of the matter?
Or given how tired you were, perhaps you were simply fried?
Y-Phil posted Fri, 14 April 2023 at 10:38 AM
Thalek posted at 10:34 AM Fri, 14 April 2023 - #4462151
Too tired indeed, to understand correctly Afrodite Ohki's funny remarkY-Phil posted at 3:24 AM Fri, 14 April 2023 - #4462135
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
peter_wade posted Fri, 14 April 2023 at 10:39 AM
ChromeStar posted at 10:53 PM Thu, 13 April 2023 - #4462117
peter_wade posted at 6:41 PM Thu, 13 April 2023 - #4462101I've had another go at this. I was entering the three numbers but the key icon was highlighted, I must have activated it accidentally when trying to click on the values. I tried to switch this off by de-selecting animated from the context menu but it still wouldn't accept my changes. Then I created a new node and this worked OK.Make sure you are entering all three values separated by commas before pressing enter. If you try to enter a single value, it won't know what to do with it and might throw it away.Thank you for the explanation, Y-Phil. I've got it working on Vicky 4 and she's looking better now.
I'll do some more tests to try and figure out how this works. If I can't find a way to re-enable editing of the values I'll put a ticket in for it.
hborre posted Fri, 14 April 2023 at 11:45 AM
It should work perfectly fine. I have no problems working with that feature. Retaining and changing the values works as it should. Either hit 'Return' or 'Enter' on your keyboard.
Afrodite-Ohki posted Mon, 17 April 2023 at 10:09 AM
My brain is even worse when I'm hungry ๐คฃ๐คฃ๐คฃThalek posted at 10:34 AM Fri, 14 April 2023 - #4462151
Y-Phil posted Mon, 17 April 2023 at 11:04 AM
What a relief! I am not alone in this case ๐My brain is even worse when I'm hungry ๐คฃ๐คฃ๐คฃ
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
DCArt posted Mon, 17 April 2023 at 12:52 PM
Y-Phil posted Mon, 17 April 2023 at 1:12 PM
Oh I've read somewhere that to help our tiring brains, there's one option among others: the music, either played or listened
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
DCArt posted Mon, 17 April 2023 at 1:41 PM
Yeah why is it I can remember the lyrics from 50+ year old songs, but not what I was reaching for the mouse to do? LOL
Y-Phil posted Mon, 17 April 2023 at 2:48 PM
DCArt posted at 1:41 PM Mon, 17 April 2023 - #4462481
Looks like you're more interested in the sixties than in your mouse
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
