3dcheapskate opened this issue on Apr 22, 2023 ยท 6 posts
3dcheapskate posted Sat, 22 April 2023 at 4:26 AM
I've had this happen a couple of times over the past week or two. I'd estimate that it happens around 5% of the time or less, but I can't yet tie it down to anything particular that I' m doing - adding pictures, deleting pictures, and/or editing test.
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
CHMedia posted Sat, 22 April 2023 at 7:52 AM
I will post your issue to our issue tracker. Thank you for reaching out.
3dcheapskate posted Sun, 23 April 2023 at 12:16 AM
When It happens again I'll post back here. I'll try to be more specific about what I was doing but, as you'll appreciate, when I'm updating a gallery item recording what I do step by step for possible bug-reporting isn't at the front of my mind.
Possibly related. A couple of days ago I was editing a gallery item. I removed one image, added a few new ones, and then saved. I got a red error message - I can't remember what it said, but remember thinking that it obviouslt doesn't like you removing an image and adding images at the same time.
lauraguo posted Wed, 26 April 2023 at 4:29 PM
Thank you for reporting this issue.
We've looked into it, and it appears that it only happens when you edit a gallery item whose multi-image slots are all filled out. So, if you click "Edit" on a gallery item and it already has all the multi-image slots filled out, clicking "Update" will cause the issue you've notice.
This should be fixed sometime tomorrow, I'll let you know when it happens.
3dcheapskate posted Thu, 27 April 2023 at 12:09 AM
That would probably fit - I may have been trying to just edit the description of a gallery item that had all 15 image slots filled.
Thanks for looking into it.
lauraguo posted Thu, 27 April 2023 at 9:58 AM
This should now be fixed--please let us know if it happens again. Thank you for your patience!
