Forum: Poser Python Scripting
Subject: Snap-To Script Update
Uncanny_Film opened this issue on Apr 24, 2023 · 3 posts
Uncanny_Film posted Mon, 24 April 2023 at 9:47 AM
Can someone Update this script to work with Poser 12?
Thanks.
# Snap-to
# Jan 9,06
# Copyright (c) 2006 by David G. Drumright (ockham)
# Select the 'mover' before hitting the script.
# Hit the script, then select the 'destination'.
# The 'mover' will go to the dest.
import poser
import string
scene=poser.Scene()
Mover=scene.CurrentActor()
if not Mover.IsProp() and not Mover.ItsFigure(): exit
from Tkinter import *
# Next section is TK
class App:
    def __init__(self, master, textMessage):
        self.master = master
        master.title("Snap-to")
        self.StatusEntry = Entry(self.master,width=60)
        self.StatusEntry.grid(row=0,column=0)
        self.master.protocol('WM_DELETE_WINDOW', self.HandleCancel)
    def ShowStatus(self,S): # Just saving repetition
        self.StatusEntry.delete(0,END)
        self.StatusEntry.insert(0,S)
        self.StatusEntry.update_idletasks()
    def Update(self):
        if scene: scene.ProcessSomeEvents(1)
        self.ShowStatus("%s is mover.  Waiting to select destination..." % Mover.Name())
        Dest=scene.CurrentActor()
        # Two ways to be a different object.  Either the Name is
        # different, or the part is on a different figure.
        Diff = 0
        DF=Dest.ItsFigure()
        MF=Mover.ItsFigure()
        if string.upper(Dest.Name())=='BODY':  Diff = 0
            # Somewhat tricky.
            # It appears that the BODY gets quietly selected very briefly before you
            # select a part, so we can't act on the BODY.
        elif Dest.Name() != Mover.Name(): Diff = 1
        elif DF and MF and (DF.Name() != MF.Name()): Diff = 1
        if Diff:
                DestX=Dest.ParameterByCode(poser.kParmCodeXTRAN).Value()
                DestY=Dest.ParameterByCode(poser.kParmCodeYTRAN).Value()
                DestZ=Dest.ParameterByCode(poser.kParmCodeZTRAN).Value()
            else:
                scene.DrawAll()
                # Locate actual center of dest.
                Geom=Dest.Geometry()
                MinX= 10000.0
                MinY= 10000.0
                MinZ= 10000.0
                MaxX=-10000.0
                MaxY=-10000.0
                MaxZ=-10000.0
                for v in range(Geom.NumVertices()):
                    WV=Geom.WorldVertex(v)
                    if   WV.X() > MaxX: MaxX=WV.X()
                    elif WV.X() < MinX: MinX=WV.X()
                    if   WV.Y() > MaxY: MaxY=WV.Y()
                    elif WV.Y() < MinY: MinY=WV.Y()
                    if   WV.Z() > MaxZ: MaxZ=WV.Z()
                    elif WV.Z() < MinZ: MinZ=WV.Z()
                DestX=(MaxX+MinX)/2.0
                DestY=(MaxY+MinY)/2.0
                DestZ=(MaxZ+MinZ)/2.0
            Mover.ParameterByCode(poser.kParmCodeXTRAN).SetValue(DestX)
            Mover.ParameterByCode(poser.kParmCodeYTRAN).SetValue(DestY)
            Mover.ParameterByCode(poser.kParmCodeZTRAN).SetValue(DestZ)
            scene.SelectActor(Mover) # return to the item we're trying to move
            scene.DrawAll()
            self.master.destroy() # Done.
        else: # Keep watching
            root.lift()
            root.after(100, self.Update)
    def HandleCancel(self):
# Activate the loop
root = Tk()
app = App(root, '')
app.Update()
root.mainloop()
# End TK loop.
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
HartyBart posted Mon, 24 April 2023 at 9:54 AM
It's been done. It's free on ShareCG as "SnapTo for Poser 12".
Uncanny_Film posted Mon, 24 April 2023 at 1:41 PM
HartyBart posted at 9:54 AM Mon, 24 April 2023 - #4463231
Got it.
Thanks
