Subject: Issue with Genesis 8 in Poser with DSON
tchamberlain2 opened this issue on May 22, 2023 ยท 5 posts
tchamberlain2 posted Mon, 22 May 2023 at 9:11 PM
Alright, I've been trying to fix this issue myself and now I'm going to ask for public help. As you can see in my image displays, I open Genesis 8 in Poser using DSON. I also use the Genesis 3/8 Expression Updater. When I take it through Bullet, everything looks right on Genesis 8 until I select soft body dynamics. Then her skin texture turns to a dark color that does not show her png texture. Can somebody show me what to do to possibly fix this or make her skin normal again? I've used bullet with Genesis 8 before and it did work.
hborre posted Mon, 22 May 2023 at 10:00 PM
I'm surprised that you even got her into Bullitt Physics.  That heavy outline is her DAZ subdivision still active, you should turn that off.  I'm assuming this is P11.  What settings do you have for the Preview, Firefly or Superfly?  Does the Material Room still look the same when you switch?  Have you tried another G8 figure just in case it's a corruption setting in?
tchamberlain2 posted Tue, 23 May 2023 at 10:46 PM
Thank you "hborre." You fixed it. Using DSON Genesis 8 (in Poser), if you turn her subdivision to -1000 Bullet Physics (soft body dynamics) will work.
hborre posted Wed, 24 May 2023 at 7:43 AM
Glad to help.
tchamberlain2 posted Fri, 26 May 2023 at 8:13 PM
Also another reason why I love Poser over Daz3d. I'm not familiar with daz having a full soft bod dynamic physics system.
