TasiaDavin opened this issue on Jun 09, 2023 ยท 4 posts
TasiaDavin posted Fri, 09 June 2023 at 7:27 PM
Anyone still around here? Looks empty but for the staff picks and such.
Do you still need to chamfer edges of walls and such for poser while modeling in a 3d cad program. And how about exporting from Blender?
Thank you
Lobo3433 posted Fri, 09 June 2023 at 10:07 PM Forum Moderator
I use chamfering on edges that will be catching lighting if we are talking corners where walls meet then no I would not and the as to exporting from Blender I would use either the OBJ format and or FBX and when importing into Poser use the scale of figure like image below and the percentage I usually go with 40% but you may need to adjust this after importing to your scene. Poser 13 has gotten better with importing but Poser native scale is a bit different than other 3D software so tweaking is something you will always have to do. Also before exporting from Blender no matter which format you use always apply scale and rotation this will save you allot of grief in the long run
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
TasiaDavin posted Fri, 09 June 2023 at 11:46 PM
Thank you very much, Lobo. I appreciate your help!
Lobo3433 posted Sat, 10 June 2023 at 8:14 AM Forum Moderator
Any time I do hope it helps good luck :thumbsup:Thank you very much, Lobo. I appreciate your help!
Lobo3433
