DownTown37 opened this issue on Jun 10, 2023 ยท 7 posts
DownTown37 posted Sat, 10 June 2023 at 5:28 PM
Point lights seem not to be working right in Poser 13 Superfly. If changing the "Dist End" "Dist Start" it does not show any effect like it does in Firefly, the point light seems to be lighting up the whole Environment like a Infinite light. Might just be on my side, would be good to know if someone else is having the same issues with this light in superfly. Or is it just not supposed to be a light to be used in superfly?
nerd posted Sat, 10 June 2023 at 5:53 PM Forum Moderator
The start and end distance controls only work for FireFly Renders. SuperFly (Cycles) represents light in a more realistic way. The setting you probably want is the Light attenuation property on the light's properties page. This will make the light intensity drop off in a realistic way.
DownTown37 posted Sat, 10 June 2023 at 6:08 PM
Yes Perfect! so no more issues, works just at it should this way. Thank you :)
(Issue solved)
hborre posted Sun, 11 June 2023 at 6:50 AM Online Now!
I addressed this answer in another post.
shvrdavid posted Sun, 11 June 2023 at 4:25 PM Online Now!
Actually, it wasn't addressed at all. Because there are ways to duplicate every Firefly light in Superfly
You can do Firefly style point lights in basically any render engine, including Superfly.
The difference, is that you don't use a light to do so in Superfly.
There are some issues with lights in Superfly compared to Cycles, because it is missing a node from cycles.
But fear not, there is a way around it. Actually, multiple ways around it.
Here, I am using a ball prop scaled down to 10%. Which is very close to the size of the Poser point light. It is just out of the scene to the right, not that far from the figures face.
Poof, point light just like in Firefly that cuts off exactly at the distance you set it too..
Yes you need to change some things to get the different falloffs.
This is Monte Carlo style lighting, in Superfly. And it obviously can be done even thou other lights follow PBR..
Everyone using Superfly should learn the LightPath node........
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
Y-Phil posted Mon, 12 June 2023 at 1:11 AM
Wow! interesting. Thank you @shvrdavid
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
RAMWorks posted Tue, 13 June 2023 at 9:04 AM
