Romeo4755 opened this issue on Jun 20, 2023 · 8 posts
Romeo4755 posted Tue, 20 June 2023 at 9:21 AM
Hello. I am still using Poser 2014.
Can I export the comic book preview in a resolution higher than my user's interface? I can change resolution in the render window, but I really like this comic BW preview.
Thank you in advance if somebody enlightens me.
Romeo4755 posted Tue, 20 June 2023 at 11:13 AM
I undocked my preview window and changed Preview dimensions, but I can't make it bigger than 1276 in width.
Y-Phil posted Tue, 20 June 2023 at 11:29 AM Online Now!
Hi
I don't have PP2014 any more, but here's what you should check:
Open Up the Render Settings Dialog, select the "Preview Tab"
Down left: define the Render Dimensions of your choice and validate:
Select "Render Now (Preview)"
PhYl.
Win10 on i7 8700K@4.3Ghz, 64Gb, Asus TUF Gaming RTX 4070 OC Edition, 2x 2Tb ssd + 6+4Tb hd + 1x 8Tb hd + 1 10T NAS, Poser 11, Poser 12 and now Poser 13
Romeo4755 posted Tue, 20 June 2023 at 12:05 PM
Thank you very much!
First of all, I got a better resolution and then I managed to make the image better. It seems to the that the image size I export from the Preview is restricted by the Render Dimentions as well.
After all efforts I discovered that Comic style actually renders too! For some reason when I tried to render it before, it switched to full textures.
Now I am very happy, the style is so oldschool and powerful, just like the character. ))
The only concern is that hair grown in the Hair Room doesn't show well enough in Comic Book style, also when I render it.
RedPhantom posted Tue, 20 June 2023 at 1:08 PM Online Now! Site Admin
Hair room hair is very limited in any preview or comic renders. You can make it thicker by checking the show populated in the hair room but it will still be very course and coloring will be limited
Romeo4755 posted Fri, 23 June 2023 at 8:50 AM
RedPhantom posted at 1:08 PM Tue, 20 June 2023 - #4468296
You are right. I understand that is so because Comic Book doesn't actually give rendered image but just a form of more accurate preview.Hair room hair is very limited in any preview or comic renders. You can make it thicker by checking the show populated in the hair room but it will still be very course and coloring will be limited
But still it looks good. ))
Thank you very much for helping, I have had a ton of new experience.
vikinglady posted Fri, 23 June 2023 at 10:18 AM
Very nicely done. 👍
IMHO it is worthy to be posted in your gallery here. "Beg🙏ging"
Y-Phil posted Sat, 24 June 2023 at 7:48 AM Online Now!
Gorgeous!
PhYl.
