722 opened this issue on Jul 02, 2023 ยท 6 posts
722 posted Sun, 02 July 2023 at 6:02 PM
I'm having problems louding characters and there limits are set to zero or a small number. i have to reset the limits in xyz and some morphes when added to a figure do not work
Poser13.0.339
hborre posted Sun, 02 July 2023 at 7:05 PM Online Now!
Could you illustrate exactly what is the problem you are having? Your description is rather vague and needs further elaboration.
NikKelly posted Mon, 03 July 2023 at 4:02 AM
Are these DIY morphs ? My problems were down to Poser only supporting linear morphs when porting models from eg MMD.
Forum gurus set me straight, literally: Sliding okay, but turning beyond small-angles fails, needs a different approach.
722 posted Mon, 03 July 2023 at 5:19 PM
the limits on the rotation and translation are not the only ones the same on some joint moments are like this too.
shvrdavid posted Mon, 03 July 2023 at 7:28 PM
Any figure that does not have the joint limits correctly set up in Poser will do what you have run into with use limits on in the figure menu. Uncheck use limits in that menu, and see if that helps.
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
722 posted Wed, 05 July 2023 at 6:52 AM
