Richard60 opened this issue on Jul 09, 2023 ยท 1 posts
Richard60 posted Sun, 09 July 2023 at 10:12 PM
If you have downloaded the Map Range Compound Node please make to fix to it. There is a missing connection.
To make the correction click the White Arrow on the upper right side of the Node (looks like an arrow going into a basket). On the lower right side inside the node find the Node called Processing Gate and find the Nod In Range 0 OoR 1. Make the connection from XOR to input 3. Exit out of the compound node and then save it back to the library.
There is a fixed version being uploaded and awaiting approval.
This will only effect the use in Daisy Chained nodes and under a specific set of conditions.
