Forum: Poser Python Scripting
Subject: Scripts for dynamic clothing...
blackbonner opened this issue on Jul 26, 2023 ยท 8 posts
blackbonner posted Wed, 26 July 2023 at 4:14 AM
Hi, I recently found an dynamic clothing item in the store that comes with a script for better/faster simulation in the cloth room. My question would be, if someone could explain to me how such script's work.
I created a  dynamic jacket for LaFemme and wanted to have the possibility to change which button of the jacket is open or closed. I tried it with the on-board Tools in Poser, but it was to complex and difficult to use.
After reading about those script's I thought I could get my project back on track this way.
I'm a complete black page when it comes to python script so I would appreciate if someone could show me at least where to start.
jancory posted Wed, 26 July 2023 at 7:41 AM
The sim script was probably produced with this tool https://www.renderosity.com/marketplace/products/149763/easy-simulation-script-generator
it makes dynamics really simple for the end user.
as for the buttons things, better minds than mine will have to help.  i think odf did something like this for one of his antonia outfits.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
blackbonner posted Wed, 26 July 2023 at 2:15 PM
Thanks, this is helpful. The tool sounds interesting. I'm using Poser since version 5 but I never thought about writing a script. Seems like time to learn something new, right?
jancory posted Wed, 26 July 2023 at 3:23 PM
new skills are always good.
i can usually hack a script but can't write one from scratch.
 My Freebies
FVerbaas posted Sun, 30 July 2023 at 3:07 PM Forum Coordinator
Changing open/close button could be done via Python but it would mean messing around with geometry so it would be very specific for that garment.
You would have to know the vertex numbers to add the polygons that make the connection. Maybe it is easier to build in all the connecting geometry (build with all buttons closed), and make the connecting polys a group per button. You can then easily delete the polygons of the connections you want 'open'. You can do that in the group tool. No need for Python, but of course that action can be scripted.
Remember: Clothify only AFTER you made the geometry changes. The cloth room uses a copy geometry and geometry changes you make to the original may/will not be carried to the copy.
blackbonner posted Mon, 31 July 2023 at 8:38 AM
@ FVerbaas, thank you for your response.Your solution sounds like something I saw in an very old dynamic cloth for V3.
The fellow who created it (SVDL is the name of the items folder) made 16 items to chose from, each with a different amount of buttons open or closed.
My initial idea using a script was to have those constrained groups saved to the library, like poses or props, it but seems not possible.
I went back to Blender and made separate material groups for each button to address them as individual constrained.
That made the selection part easier, but I couldn't figure out how to have more then one constrained group at a time and I didn't see how I can save them.
So, it seems that I have to go back to Blender and detach each button and save each step as a morph.
Your last hint means also I have to add a morph before the clothing item gets clothifyed, do I understand that right?
This was very helpful, thank you very much.
FVerbaas posted Tue, 08 August 2023 at 2:45 PM Forum Coordinator
What I meant is that you make the clothing model with polygons that provide the structural connection a closed  button would provide, so bridge between two vertices of the button base stitches and two vertices of the button hole, and define groups named say 'button 1 closure', 'button 2 closure', etc. These groups then to contain each the polygon(s) representing the closure of their button.
In the group tool you can select easily the groups, and hence the polygons, representing the closure of the buttons you want to open, and then delete the polygons, thus breaking the connection. It is not a matter of morphs, and when done properly it will not change the vertex numbering. The only change is there are a few polygons less.
Zippers you could do the same way, defining a narrow row of polygons connecting the two sides. You could then box-select the polygons not to be deleted. Obviously this will not move the zipper, but that can not be avoided.
blackbonner posted Sat, 26 August 2023 at 7:40 AM
@FVerbaas, thank you for the explanation. Sorry for my late response, I was on vacation until yesterday.
I will check out what you have suggested as soon as I have installed and tested the new Poser Version that came out during my absence.
