Forum: Poser 13
Subject: Slowdown in Poser 13.1.449 in some cases
Y-Phil opened this issue on Aug 20, 2023 ยท 12 posts
Y-Phil posted Sun, 20 August 2023 at 11:53 AM
Your experience may vary, but on my system, using my nvidia RTX2080Ti, there's a HUGE slowdown in computing, when I compare the same scene computed with Poser 13.0.339 and this new 13.1.449 version, at least when ScatterVolume is used.
Here's the scene:
Kalewksi's RKDungean3, a vase using a procedural material, 4 spheres on the ceiling + 1 in the vase (light emitters), a smoke object and a huge cube (using ScetterVolume as I still don't understand how to correctly use the new PrincipledVolume).
The settings I've used are the default "OptiX high" except that the pixel samples are set to 20 instead of 25 and the bucket size set to 2048
Poser 13.0.339: ~45 seconds using OptiX and ~59 seconds using GeForce
Poser 13.1.449: ~211 seconds using OptiX and ~264 seconds using GeForce
Without the Fog cube and the Smoke objects (both ScatterVolume)  both Poser are computing the scene below 15".
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
Y-Phil posted Sun, 20 August 2023 at 1:11 PM
I've found a culprit: the Clouds node, avoidable using the new PrincipledBSDF.
Using these settings:
I like the new smoke, more convincing
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Rhia474 posted Sun, 20 August 2023 at 1:29 PM
Great find, saving that matsetup. Thank you!
Y-Phil posted Sun, 20 August 2023 at 1:43 PM
Rhia474 posted at 1:29 PM Sun, 20 August 2023 - #4473125
You're welcome
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
petrusvitus posted Fri, 08 September 2023 at 2:33 AM
How you create the smoke... or where to buy ? sorry out topic.
Y-Phil posted Fri, 08 September 2023 at 4:34 AM
petrusvitus posted at 2:33 AM Fri, 8 September 2023 - #4474223
I'm not able to create such objects. I've bought it on turbosquid as I haven't found what I was looking for here
https://www.turbosquid.com/3d-models/3d-smoke-pack-25-1491997
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
petrusvitus posted Fri, 08 September 2023 at 5:53 AM
Thanks for the info. That smoke can be animating in poser?
Y-Phil posted Fri, 08 September 2023 at 6:11 AM
petrusvitus posted at 5:53 AM Fri, 8 September 2023 - #4474230
They are static objects, but you may modify them in Poser using the morphing tool or in Blender, for example.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
petrusvitus posted Fri, 08 September 2023 at 8:47 AM
I  see. how do you make the material. Can you share screen shot. Thanks in advance..
Y-Phil posted Fri, 08 September 2023 at 9:07 AM
I really don't master correctly Poser13's new PrincipledVolume, but here an example to start with
The bright contrast node helps me to have the same color but darker
If the emission strength is too high, you'll end up with nothing to see
In the example below, I've setup a vase with a strong blue source spot (1000%)
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
petrusvitus posted Fri, 15 September 2023 at 2:20 AM
Thanks for share.. Now I can make cloud with it.
Y-Phil posted Fri, 15 September 2023 at 6:14 AM
Cool
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
