FATfoe opened this issue on May 18, 2001 ยท 9 posts
FATfoe posted Fri, 18 May 2001 at 9:36 AM
AzChip posted Fri, 18 May 2001 at 10:15 AM
cristianr posted Fri, 18 May 2001 at 11:09 AM
Very impressive indeed. Just do what AzChip suggested and it will be even more impressive.
FATfoe posted Fri, 18 May 2001 at 11:51 AM
Thanks for the advice AzChip Ill try that
MarkBremmer posted Fri, 18 May 2001 at 6:22 PM
Nice work!
Izuel posted Fri, 18 May 2001 at 7:42 PM
Smooth! are you sure you made that in carrara?
Kixum posted Fri, 18 May 2001 at 10:42 PM
Have you tried making the glass real glass with the refraction and seeing if Carrara would actually calculate the funky caustics? Supposedly it's supposed to be able to do that. At a minimu, you'd get the light of the arms through the glass tweaked correctly. RDS could pull that magic trick off. If you do the gel and the refraction, I agree that it would look just like a real photo. Good job for inspiring all of us!
-Kix
rockjockjared posted Sat, 19 May 2001 at 4:03 AM
Kixum -- I've tried to play with Carrara and "real" caustics. I was working on a magnifying glass over a book and it turned out quite weird! Unfortionately I don't think Carrara has that great of a raytracing engine...or I could have just been doing something wrong (which is probably closer to being correct!) Jared
ewinemiller posted Sat, 19 May 2001 at 9:02 AM
Carrara doesn't support caustics. Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
