giotim opened this issue on Aug 22, 2023 ยท 5 posts
giotim posted Tue, 22 August 2023 at 3:57 AM
Hi to everyone!
i need an help, i've imported from Sketchup an .OBJ (first screenshot) of a boat in Poser 11 (second screenshot) and i don't know why inside the hull, rounded in red, the walls became invisible and we see through them. Only the internal walls, as you can see the externals remain. And this happen even if i import it in .FBX, 3DS, etc.
Is the problem the file itself of Sketchup? or is the importing in Poser? can anyone help me?
Thank you!
EVargas posted Tue, 22 August 2023 at 7:10 AM
I wonder if this has to do with those parts being single sided meshes.Take a look at the properties tab on your screen right, there is an option somewhere saying something along the lines of "force backfaces display".
FVerbaas posted Tue, 22 August 2023 at 7:14 AM Forum Coordinator
It may be a question of the direction of the normals. By default Poser, in preview, does not show facets that have normals facing away from the camera. They will show up in render. Switch on ' show backfacing normals' to see them in preview.
RedPhantom posted Tue, 22 August 2023 at 7:41 AM Site Admin
As the others are saying, it looks like the back faces of the normals aren't displaying. To get them to display, go in to your render settings. On the preview tab, check show back facing. They should show then.
giotim posted Tue, 22 August 2023 at 9:31 AM
thanks to you all, i didn't know this option, you saved me!
