Forum: New Poser Users Help
Subject: Delete Frames inside an animation
HBalckl opened this issue on Sep 05, 2023 ยท 3 posts
HBalckl posted Tue, 05 September 2023 at 9:20 PM
Hallo,
Its possible in Poser2012 or 2013 to delete frames inside an animation - for example in an 30 Frame animation I like to erase frame 2 and 4 ?
For now - I found no way, to do that.
Thank you
Richard60 posted Wed, 06 September 2023 at 8:39 PM
Poser does not have a delete this key frame and have everything move over automatically.  However, you can do the following to get the same results you are looking for.
1:  Open the animation palette.
2:  Collapse all the body parts etc. to the smallest number of items on the palette. (makes it easier to highlight them)
3:  Highlight all the keys on the third frame.  That is drag a box from the bottom to the top to highlight all the parts
4:  Click and hold the left mouse button on the top key frame and drag frame 3 to frame 2 and then release the button.
5:  Same as step 4 except now drag and highlight everything from frame 5 to frame 30.  Again, click and hold the left mouse button and drag the keys from 5 to 4 and release.
6:  Shorten the movie from 30 frames to 28 by changing the 30 to 28 and you are done.
Maybe not as easy as just deleting the frame as you were looking for but it does work.  One thing to remember is that IF you like the movement on frames 3 and 5 make sure to highlight each of those frames in order and make sure to make every part a keyframe or you may end up deleting a Key and causing the resulting animation to go off in weird directions.
HBalckl posted Fri, 08 September 2023 at 10:52 AM
Thank you so much !!!
