Tynkere opened this issue on Sep 07, 2023 ยท 6 posts
Tynkere posted Thu, 07 September 2023 at 5:59 PM
Title says it all I guess. My notes from years ago don't say much. 'Dart. Tut. World Creator. Import grayscale.'
Carrara can use grayscale to make 100m to 1000m ground plane, or was that Bryce?
PS: Not seeing any topics other than an announcement & Wendy's sharing an animation. "Browse archives" doesn't seem to do anything. Normal or got wiped when forum was closed?
WendyLuvsCatz posted Thu, 07 September 2023 at 6:02 PM
try https://www.renderosity.com/forums/106/carrara?start_date=01%2F01%2F2003&end_date=08%2F09%2F2023
Tynkere posted Thu, 07 September 2023 at 6:07 PM
Thanks. Lot of content to scroll through. Bound to be something. ; )
ProPose001 posted Sat, 09 September 2023 at 3:14 AM
Not aware of any tutorials on the subject, but.....
Yes, Carrara can use Grayscale images to create terrains. Start with an empty scene, then drag in a Terrain object via the tool icons or front the Insert Menu drop-down.
That will get you into the terrain editor, from where you have lots of options in creating a terrain using the tools in the editor. If you're not comfortable with the painting tools of the editor the you can Clear the canvas using the 'Clear' button and 'Import' a height map or displacement map available from numerous sources on the Web to generate a terrain, real world or otherwise. First thing I would do though, is READ the MANUAL. I know the documentation sucks, but even the Carrara 6 Manual that comes with Carrara 8 has a wealth of info that will help
Tynkere posted Sat, 09 September 2023 at 4:31 PM
Hmmm... Feels like an empty tavern. Where is everyone? I guess they've moved to social media, or... More about that later.
Anyway, after plowing dozens of different ways to phrase search terms, Google did have the link I remembered. Many thanks to "Dartenbeck."
https://www.daz3d.com/forums/discussion/37867/building-carrara-terrains-intro
Thanks for reply & enjoy weekend!
PS: On an iPad using DDG, Rendo has this annoying "accept cookies" notice at the bottom of the screen. The notice is sized perfectly to hide the reply button. Was fun posting here while it lasted.
Third party requests loaded as part of accepting:
Google Ads
Amazon
jquery
WendyLuvsCatz posted Sat, 09 September 2023 at 6:40 PM
yeah DAZ forum the better place to ask questions
Map Editor is where you can import a greyscale map
also http://docs.daz3d.com/lib/exe/fetch.php/artzone/pub/software/carrara/carrara7_user_guide.pdf
which weirdly doesn't mention this
so ignore RTFM comments in this case at least
