mmitchell_houston opened this issue on Sep 12, 2023 · 8 posts
mmitchell_houston posted Tue, 12 September 2023 at 11:16 PM
Okay, I'm having a brain f*rt right now. I'm working in Poser 13 and I have a LARGE scene (Goldenwood vol 1 & vol 2). When I try to pull waaaaay back, the geometry is getting "clipped" and it vanishes when it reaches a certain distance away.
• I do NOT have "Depth cued" turned on
• I have experimented with many different focal length settings (from 10 - 100)
• I have tried multiple display settings, include the default preview and the Comic Style
SO, what boneheaded setting have I hit that I need to change?
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM | 14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com | Poser Noir Comics Tutorial | Illustrations Honored by Renderosity
Y-Phil posted Wed, 13 September 2023 at 6:39 AM
On each camera, you have these two values:
Hither controls the smallest distance between the cam and any object: smaller = invisible, larger = visible
Yon controls the opposite: smaller = visible, larger = invisible
So, to be visible, an object must be in-between. Which explains why when you zoom out too far, part of your scene may become hidden, you'll just have to increase Yon till you can see them again.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RedPhantom posted Wed, 13 September 2023 at 7:11 AM Site Admin
Rather than small vs. big, hither and von control clipping on distance close vs. far in relation to the camera. But otherwise, Y-Phil is correct.
Y-Phil posted Wed, 13 September 2023 at 9:59 AM
RedPhantom posted at 7:11 AM Wed, 13 September 2023 - #4474513
Lol... I was pretty sure I didn't have the right words...Rather than small vs. big, hither and von control clipping on distance close vs. far in relation to the camera. But otherwise, Y-Phil is correct.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
mmitchell_houston posted Wed, 13 September 2023 at 3:49 PM
Thank you BOTH so much. I knew it was something simple that I wasn't doing correctly. This is EXACTLY the info I needed!
NikKelly posted Wed, 13 September 2023 at 5:03 PM
FWIW, 'HITHER' can provide Muggles' X-Ray vision, by letting you position camera outside room and make intervening wall / tall furniture invisible.
Handy for forest scenes, too, when otherwise ideal camera location is right behind a tree...
Y-Phil posted Thu, 14 September 2023 at 1:11 AM
NikKelly posted at 5:03 PM Wed, 13 September 2023 - #4474558
Intersting, thanksFWIW, 'HITHER' can provide Muggles' X-Ray vision, by letting you position camera outside room and make intervening wall / tall furniture invisible.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
mmitchell_houston posted Thu, 14 September 2023 at 3:42 AM
Thanks. I played around with that and it worked like a charm. I made a house wall vanish without having to toggle visibility on the wall! Neat trick!FWIW, 'HITHER' can provide Muggles' X-Ray vision, by letting you position camera outside room and make intervening wall / tall furniture invisible.
