Forum: Carrara
Subject: Removing unused and dublicated channel
ibm386 opened this issue on Oct 03, 2023 ยท 4 posts
ibm386 posted Tue, 03 October 2023 at 3:12 PM
Hello! How to remove morph channel?
Poser can make a inj-file but can't create a morph rem-file, I used another tool to create a rem file but without success, channels just hidden but not deleted.
This not work
WendyLuvsCatz posted Wed, 04 October 2023 at 5:46 AM
you could delete them in the vertex room under morph but no idea why you would want to.
Just zeroing better as not gone for good.
Animation zero selection should do it depending on the figure (legacy or genesis +)
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
ibm386 posted Fri, 06 October 2023 at 3:29 AM
Unfortunately no. You can edit a morph in vertex edit mode but you can't delete it. I'm using legacy poser figure.
I need this because the pz exporter is bugged and has created morph channels with the same name and now the pz2 and fc2 facial expressions don't work correctly.
WendyLuvsCatz posted Fri, 06 October 2023 at 4:40 PM
you may need to do some editing in Notepad++ then I am not very versed in editing Poser files but it is possible
I have myself used DAZ studio to create ExP injection and Remove files and Deltas using Carrara made morphs in Morphloader etc
there is a lot of documentation out there on it
at least whatever you do in Carrara will not effect your runtime so when working in DAZ studio remove your main content library from the directory and add a temporary one with just the content you need and work on that.
then you can add that to your Carrara browser too with less baggage
Tom R. Toe
