tomasball opened this issue on Oct 05, 2023 ยท 4 posts
tomasball posted Thu, 05 October 2023 at 8:02 AM
HI, I installed VWD on Daz studio some time ago, and have used it successfully several times. Today I can't make it work, and I wonder if I have had a stroke and forgotten some important part.
I make a scene with a cube and a plane. The plane is above the cube and the time line is 30 frames
I start VWD, select the cube and press collision and again press collision. now the list says collision next to the cube
I select the plane, select cloth, and again press cloth. Now it is labeled as cloth.
Now I select simulation, and then select start dynamic simulation.
It runs through the timeline, but the plane does not move at all
. Does that sound like I'm doing something wrong?
fuqol217 posted Wed, 11 October 2023 at 4:41 AM
Hi tomasball
I'm not an expert, but a keen user. What you are doing sounds ok, but when I did it I got the same result - nothing moved. Then I noticed I had GPU selected for the simulation, which seems to be a problem nowadays.
So I changed to CPU for the simulation and it worked perfectly.
Other things to consider if it still has problems (sorry if this is obvious): Try restoring default parameters; and make sure your primitives have a good number of divisions when you create them.
randolphshaw4 posted Tue, 24 October 2023 at 2:31 AM
Try restoring default parameters, and ensure that your primitives have a sufficient amount of divisions when you create them. rainbow obby
tomasball posted Tue, 24 October 2023 at 9:07 AM
It was the restore default parameters I was missing. Thanks all.
