GaryChildress opened this issue on Oct 14, 2023 ยท 2 posts
GaryChildress posted Sat, 14 October 2023 at 4:40 PM
A few years back, I needed to create a Mike 4 with a dark complexion. In order to do that, I fiddled around with the texture files for Daz M4. Unfortunately, I have never been able to get M4 back to factory specs. As you can see in the picture below there are noticeable lines at the neck and hips where the shades of skin don't match up. I've tried everything to set it back to the original. I downloaded the M4 Base from DAZ about an hour ago and tried to copy the default DAZ textures over the old ones I still had but it still has the same lines. Is this the default way that M4 comes from DAZ? Or am I missing a setting that will get rid of the lines. I've checked the basic settings such as Diffuse Color. That seems to be set to 255,255,255 white, which is the default setting. So I don't know where the shading is coming from. Any ideas?
Thanks.
Please visit My 3D Freebies
Thank you for your patronage!
JustBeCause posted Sat, 14 October 2023 at 5:34 PM
you get this effect because the Bump map is attached to the Gradient_Bump Node :) remove the node or attach it to Bump
here is a MC6 Mat file that will fix your issue hope there was no changes of the mat path but should actually work.
