JagoBC opened this issue on Nov 19, 2023 ยท 4 posts
JagoBC posted Sun, 19 November 2023 at 1:10 AM
So I have a figure built on the David base, but when I go to save it in the Library, the teeth go all monstrosity, and it looses all the full body changes I made.
The images show what happens to the teeth. And I don't just mean it saves to the library like that, I mean, it actually changes the model in the open file I'm saving from.
This one is driving me insane, because I've already rebuilt the character three times.
JagoBC posted Sun, 19 November 2023 at 1:14 AM
Not quite sure what happened to the pics.
nerd posted Mon, 20 November 2023 at 1:34 PM Forum Moderator
When you edited the figure did you actually change any geometry groups. That is Work in the Setup or Fitting room or using the Grouping tool? If the answer is No then when saving the figure to the library choose the option to Keep the existing geometry.
This is happening when new geometry in generated the morphs and weight maps have to be copied in the new geometry. Places where the vertexes are in exactly the same place ... well you see what happened. If you preserve the existing geometry this won't happen. The flip side if you changed material groups with the grouping tool or made any rigging changes in the setup room they will be lost.
The next service release of P13 will include improvements in this area.
JagoBC posted Thu, 23 November 2023 at 12:30 AM
I only understood about 3/4s of that, but using the other save option did solve the problem. I mostly just use P11 to animate and build in Blender. I've never been in the Setup or Fitting Rooms. I do, however, use the grouping tool a lot.
Anyway, thanks for solving my problem!
