arrow1 opened this issue on Jan 11, 2024 ยท 3 posts
arrow1 posted Thu, 11 January 2024 at 5:01 PM
When and how do I assign UV maps in Poser 13? Is it done in the material room? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
randym77 posted Thu, 11 January 2024 at 6:03 PM
If you mean something that isn't UV mapped...I think you have map them in other applications like UV Mapper or Blender.
FVerbaas posted Fri, 12 January 2024 at 5:07 AM Forum Coordinator
uv domain mapping (vertices and polygons) usually comes, in the .obj file as one set with the xyz domain mapping. Same holds for uv domain mapping.
There is, in Poser, currently no method to combine or swap out uv maps. If you have a separate mapping for the uv domain, but with consistent, or at least mapped, order of the polygons as in the xyz domain mapping you could write a small script to combine them, either in memory or in a .obj file.
If you want to pursue this your main tool there would be the below method in the geometry type:
polygons, sets and vertices can be obtained from the xyz geometry using the proper methods. The optional input parameters texPolygons, texSets, texVertices would have to come from your custom uv definition. This could be a normal .obj based input. A polgon (facet) definition in a .obj requires vertex data. You can do with just 4 vertices repeated for every polygon.
