Forum: Suggestion Box
Subject: Attaching text files in PoserPython Scripting forum - please get it to work
3dcheapskate opened this issue on Jan 15, 2024 ยท 1 posts
3dcheapskate posted Mon, 15 January 2024 at 6:10 AM Online Now!
See the comment at the bottom of the first post here -  What changes are needed to get this to work in Poser 12+ ?
(in case you can't find it it's the bit that says "Footnote: code above cut-and-pasted from NotePad++ after changing EOLs to just LF. Also attempting to add RandomizeHexGeometries.txt to this post below" I followed the instructions at the top of the forum, annotated screenshot below (I used drag-and-drop) but it didn't work
I've tried to attach the same text file to this post via the other method, i.e. the "Picture" button above the message edit box followed by the "Choose File" button from the "Insert Image" popup. That doesn't work either.
Please could you fix it. :o)
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
