tastiger opened this issue on Jan 19, 2024 ยท 2 posts
tastiger posted Fri, 19 January 2024 at 9:24 PM
OK so I surrendered and decided to give D|S a go, worked well with characters until I tried Genesis 9.
WTF is going on here, I'm bewildered?
This is Genesis 9 straight out of the box and installed using the DIM.
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
RHaseltine posted Sat, 20 January 2024 at 6:54 AM
You have at least one other morph installed that has a non-zero default value. Edit>Figure>Zero>Zero Figure Shape, Edit>Figure>Memorise>Memorise Figure Shape, then go to File>Save as>Support Assets>Save Modified Assets and make a note of the shapes listed, then cancel (actually saving can overwrite some things that should have non-zero defaults). Once you know the culprits you can check for updates, uninstall them, or save a preset with them zeroed and use that to load the figure in future.
