Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Problem creating animation pose
bdpoppa opened this issue on Jan 22, 2024 ยท 4 posts
bdpoppa posted Mon, 22 January 2024 at 3:10 PM
I created an animated figure in which the only thing I changed was the Z Scale on parts of the figure to make them move.  When I save the pose everything saves except the Z Scale change.  I am running Poser 11 Pro.  Am I trying to do the impossible?
saibabameuk posted Tue, 23 January 2024 at 1:52 AM
Post the animation les see how it turns out even with the fault !
How are you exporting the animation? Just interested in your subject and happy to chat about animation. https://youtu.be/grDfmBLCmQc?si=e6sAHNUnR92uqYxx
bdpoppa posted Tue, 23 January 2024 at 10:43 AM
Simply saving it as a mult-frame pose.  Tried with and without Morph Channels and Body Transformations.
KageRyu posted Mon, 08 April 2024 at 6:28 PM
In the process of saving the pose there should be a window with tick boxes for Morph channels and Body transforms - to save scaling you must tick the Save Body Transformations.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
