Thu, Mar 27, 10:16 PM CDT
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Mar 27 10:02 pm)
Subject: Snarly's scripts
  • 1
  • 2
Y-Phil ( ) posted Fri, 07 February 2025 at 7:37 AM · edited Fri, 07 February 2025 at 7:38 AM
First, connecting external nodes to a compound node does not seem to always work as connecting standard nodes, I mean by using the InputByInternalName method, that's why I'm often using an index, not the best method but it works.
Then, the code you are speaking of is just a way to have convenient names. It's true that the code may not be adapted to the said node, as two identically labelled Value_2 node inputs must be exposed as inputs of the compound node, but labelled differently, a situation that I have avoided during the development of PBSDF addon.
That being said, did you check the online help for Poser?
Typically when it comes to Cycles, you may start here:
https://www.posersoftware.com/documentation/13/HTML/index.htm#t=Poser_Reference_Manual%2FMaterials%2FNodes-Cycles%2FCycles_Nodes.htm
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gaming, Asus Tuf Gaming RTX 4070 OC Edition, 1+2 TB SSD's, 6+4TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
𝑀𝓎 𝒢𝒶𝓁𝓁𝑒𝓇𝓎
Y-Phil ( ) posted Sun, 09 February 2025 at 4:26 PM · edited Sun, 09 February 2025 at 4:27 PM
Just a small update, to sum up links for the last EZSkin version and the last plugin for skin:
Actually: it's V3.4:
https://kdrive.digital-paradize.com/app/share/116364/c9c3812b-e75f-42c0-842f-ca98da3a412c
Cycles plugin for skin, based on PrincipledBSDF, last update here:
https://kdrive.digital-paradize.com/app/share/116364/7a305ed4-4dec-48a5-a61e-58ab586e9002
The difference: an weird while border around Vic4's pupil. I've rebuilt the compound nodes for the iris, the sclera and the pupil, based on what Ghostship shared with us.
Before:
Now:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝑀𝓎 𝒢𝒶𝓁𝓁𝑒𝓇𝓎
CobraBlade ( ) posted Thu, 13 February 2025 at 2:12 PM
Thank you for your continued work and fixes. My mirror has also been updated to these latest versions.
Poser scripts by Snarlygribbly
CobraBlade ( ) posted Thu, 13 February 2025 at 3:49 PM · edited Thu, 13 February 2025 at 3:49 PM
I just discovered I have to make eyebrows invisible for M3, or EZ_CycleSkin will give him white caterpillars.
Default <- -> EZSkin EZ_CycleSkin applied
Mark111111 ( ) posted Sun, 23 February 2025 at 4:01 PM
good man very good
Y-Phil ( ) posted Thu, 06 March 2025 at 8:59 AM · edited Thu, 06 March 2025 at 9:04 AM
EZSkin's Cycles for Skin plugin has been updated.
You nay download it from here, till CobraBlade's EZSkin page is updated:
Now, the face, the lips, the nipples and the standard skin may also receive an additional layer (using the AnisotropicBsdf node) by selecting the ..._gloss layer.
Full example:
Note that the face has 4 possibilities:
The strenth of the anisotropy relies on its Roughness parameter: lower value increases the gloss
The new layer is called Gloss, and it get deleted each  time EZSkin rebuilds the whole materials. It looks like this:
And don't forget to save your new glossy characters for a future use:
Everything is saved each time EZSkin is closed.
Don't forget to use it with EZSkin  3.5:
https://kdrive.digital-paradize.com/app/share/116364/ae7a51aa-8f4f-4792-99ff-abdd1b2a863b
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝑀𝓎 𝒢𝒶𝓁𝓁𝑒𝓇𝓎
Snarlygribbly ( ) posted Thu, 06 March 2025 at 12:48 PM
Nice to see that you guys are keeping the fires burning :)
Free stuff @ https://poser.cobrablade.net/
CobraBlade ( ) posted Thu, 06 March 2025 at 4:26 PM
The legend himself, Snarlygribbly. It's great to see you on here!
It goes without saying, but if it wasn't for your EZSkin (and Y-Phil's work on it now) a lot of us would never have bothered using SuperFly over Firefly.
Updated the mirror:
However, I did rename EZSkin.py back to EZSkin3.py to avoid confusion since the instructions and manuals all refer to it named that.
Y-Phil ( ) posted Thu, 06 March 2025 at 5:24 PM · edited Thu, 06 March 2025 at 5:24 PM
Snarlygribbly posted at 12:48 PM Thu, 6 March 2025 - #4494092
Hi... nice to "see" you here form time to time g9DoJgm5OOLzRlqVviVTBa9RvDitLdrUSq6rHFPf.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝑀𝓎 𝒢𝒶𝓁𝓁𝑒𝓇𝓎
  • 1
  • 2
