Subject: Control chips and dynamic clothing
randym77 opened this issue on Feb 13, 2024 ยท 7 posts
randym77 posted Tue, 13 February 2024 at 11:10 AM
Been having some issues with La Femme (both versions) and dynamic clothing. I think the problem is checking the "ignore hand collisions" or "ignore head collisions" doesn't remove the control chips from collisions.
Expanding the hierarchy and looking for all the control chips in each finger, etc. is a pain. Is there another solution? Is there something I can do to permanently make LF's control chips non-collidable? (I can't imagine a situation where you'd want clothing to collide with the control chips.)
Y-Phil posted Tue, 13 February 2024 at 1:29 PM
If the idea is to avoid each hand, on windows we only have to alt-click to unselect the hand and everything below, the control chips included are unselected. Same for the head.
I don't know the equivalent on Mac.
Same effect to select everything. And it works on P11 & P13.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
RedPhantom posted Tue, 13 February 2024 at 1:34 PM Online Now! Site Admin
It shouldn't even be colliding with chips. You can also try using the hide controls dial.
primorge posted Tue, 13 February 2024 at 2:39 PM
If the hide controls dial doesn't work (which controls the animated properties of the visibility, as in the visible from Properties or Hierarchy, not sure, as in don't know, if or how that property would relate to collisions in regard to sims) you can try this...
Float Controls INJ
Download the zip and put the 3 files together in any pose folder in your library. It's a pmd inject. When applied to LF Pro (1) it "translates" all of the control chips in the Y direction...
At full strength (1) it translates the polys quite a bit...
The dial can be found in the Controls Section of LF's Body...
Note this is not a true transform but rather a morph: that is, the polys vertice coordinates are altered but the centers/origins in Poser terms are not. In any case it gets those poly vertices out of the way, which I think would be the quality related to collision calculation.
DeeceyArt posted Tue, 13 February 2024 at 3:40 PM
When you use the Hide > Show Control Handles setting (it's in the BODY actor of the figure), are you setting that to 0 or 1?  Setting to 0 should hide the control chips (that's what I'm seeing here on both LF1 and LF2).
Also ... when you are talking about hand control chips, what you might actually be referring to are the hand BONES. Control chips are used in the face for expressions. But those extra bones in the hand, breast, and buttocks should also disappear when you set Hide > Show Control Handles to 0 (not 1).
DeeceyArt posted Tue, 13 February 2024 at 3:50 PM
Select the BODY actor of the figure
You'll see the Hide > Show Control Handles setting there.
Set to 0 to hide all of the control handles.
randym77 posted Tue, 13 February 2024 at 6:53 PM
I guess there must be something weird with my setup, if I'm the only one having this issue.
This is with the control chips hidden:
This is what I get if I turn off collisions on the control chips manually:
Have not tried the Float Controls thing, but I will. It looks interesting.
