davo opened this issue on Feb 29, 2024 ยท 4 posts
davo posted Thu, 29 February 2024 at 1:26 PM
Is it possible to have a hand pose plus a smart prop added to the same hand at the same time? Daz Studio has this feature available called "wearable preset" which is like a smart prop but also allows you to pose the character at the same time. Is this feature or similar available in Poser? It would be nice.
Thanks!
davo
Y-Phil posted Fri, 01 March 2024 at 6:08 AM
Many Pose files (*.pz2) are using readSCript to load a collection of morphs/partial poses, etc...
Exemple:
So that I suppose that it should be possible to create a pose file or a props file that loads two files dropped in a dedicated place of a runtime's structure.
But I don't know if there's a tool to create this, I think that it should be easy to create it using a Python script.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
KageRyu posted Mon, 08 April 2024 at 1:41 AM
I am pretty sure this IS possible, I have a working theory, but I would need to run a few tests. In short it would involve some editing of the PP2 I believe...as Y-Phil suggests. I would need to see how much needs embedded, and where to embed. I think you might be able to embed partial pose data and a few needed lines to target a figure from a Pose of the hand into the PP2. Make backups before trying. I suggest using Notepad++ with the Poser extension for the editing.
I have done this to embed prop positioning in a figure pose with parented props for some time...but not loading the pose with the prop.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
Y-Phil posted Tue, 09 April 2024 at 7:23 AM
I think that it should be possible to have a pz2 file with one readscript that loads the prop and the other that loads the pose for the hand.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
