Subject: Victoria 4 Breast Morphs
generation2235 opened this issue on Mar 02, 2024 ยท 7 posts
generation2235 posted Sat, 02 March 2024 at 4:49 PM
Of the several breast morph packs I have in my Runtime for Victoria 4 there is one particular V4 breast morph I am looking for that will change the angle of the areola and nipple. My goal is to create more of an 'aging breast' effect that the 'Breast Droop' and Areola Height' can't quite achieve. I'm looking to angle the areola and nipple downward. Is there a morph pack for Victoria 4 breasts that can achieve that?
Thanks.
Y-Phil posted Sun, 03 March 2024 at 8:46 AM
The nearest pack I can think of is X & M's Perfect V4 Complete:
But I truly does not know if their pack can still be found anywhere. Furthermore, this pack is using Poser11-only compatible python files. Quite a few differences are present in Poser python 3.xx version: not only the print instruction that became a real function but also one of their script is using a listbox to allow the user to select which morph to import, and  its definition has evolved.
Nothing impossible to adapt, though, as the scripts are source ones, not compiled ones
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
generation2235 posted Tue, 12 March 2024 at 5:28 AM
Thanks. I'll keep looking around for this although so far only found the add-ons for the original morph pack which is listed in Rendo as 'unavailable'
generation2235 posted Thu, 04 April 2024 at 6:12 PM
Y-phil, I've loaded the PerfectV4 Complete Supermorph preload, the 'Inject All Fixes' and I've loaded all of the .py scripts via the 'Inj Script' but how were you able to get the Nipple Conformer, R-nipple and L-nipple under the Chest to show up in the Hierarchy editor?
Backfire2024 posted Fri, 05 April 2024 at 9:12 AM
generation2235 posted at 6:12 PM Thu, 4 April 2024 - #4483263
Perfect V4 does not seem to have any R-nipple and L-nipple, These can be found officially in the V4 Weight map edition ( LeftBreast, RightBreast ) or the SASHA-16 versions ( Right Nipple, Left Nipple, RightBreast, LeftBreast, Breast Deformers - ignore / collapse ) or some less known alternative V4 versions.
hborre posted Fri, 05 April 2024 at 9:20 AM
If there is a nipple morph, that can be split into separate left- and right- dials.
Y-Phil posted Mon, 08 April 2024 at 2:35 AM
Sorry but that last week-end I've been overbooked and I didn't found the time to search further. I'll keep you  informed asap
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
