Festiwebtele opened this issue on Mar 29, 2024 ยท 9 posts
Festiwebtele posted Fri, 29 March 2024 at 8:03 AM
Hi everyone, I am making a movie with poser 12. Everything goes well, but I decided to try Poser 13. At first, no problem, but something went wrong on my last scene. (see images). At first, I thought that was bcause of the distance (a lttle far away of X and Z =0) But that dont make sense, because the character was at the same position of the previous scene and everything was ok. I try almost everything ; free the ram, reload, save PZ 3 again, reload the file in poser 12 and save again and try...again with poser 13. Nothing works. So I am back with poser 12. Someone, has an idea of what went wrong ?
ChromeStar posted Fri, 29 March 2024 at 10:37 AM
It looks like it's just on the character's skin, so probably a shader problem. Can you post a picture of the material for the character, for the arm, face, or neck?
Festiwebtele posted Fri, 29 March 2024 at 11:22 AM
Sure.Thanks. It work well with Poser 12, but may be it's too simple for P13.
hborre posted Fri, 29 March 2024 at 12:06 PM
The problem with the old skin shaders is that the creators continue using old hacks and outdated channel connections that are no longer appropriate for Superfly or Firefly rendering. Aside from unticking the Reflection_Lite_mult box, I would try disconnecting the Gradient_Bump channel or reducing its value to 1 or lower.
The other recommendations I suggest are disconnecting the color texture from the Specular_Color connector (should use a grayscale map for that) and reducing both the Diffuse_Value and Specular_Value values (0.85 and 0.5, respectively).
Keep in mind, some of those material shaders are very old and are no longer valid in the current Poser iteration. There have been changes between P12 and P13 to correct problems that were always there since the beginning.
RedPhantom posted Fri, 29 March 2024 at 12:29 PM Site Admin
Festiwebtele posted Fri, 29 March 2024 at 1:49 PM
Thanks Guys! The poser community is really great ! I'll check in my library to find a newer M4 maps and try it in Poser 13 again.
ChromeStar posted Fri, 29 March 2024 at 2:48 PM
Festiwebtele posted Fri, 29 March 2024 at 5:47 PM
Thanks you a million time ! It's now ok!
Festiwebtele posted Fri, 29 March 2024 at 5:48 PM
Here,s the result :-)
