mdbruffy opened this issue on Apr 19, 2024 ยท 8 posts
mdbruffy posted Fri, 19 April 2024 at 8:12 PM
Okay. I broke down and bought Poser 13. Now would someone please tell me where the ^*% content folder for the Runtime is? I''ve checked the Program files,I've also looked in Documents. Nothing. Seems like every time I get a new version of this thing, they move it.
Sunfire posted Fri, 19 April 2024 at 8:41 PM
In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
mdbruffy posted Fri, 19 April 2024 at 8:53 PM
I'm looking at Local Disc (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
RedPhantom posted Sat, 20 April 2024 at 7:42 AM Site Admin
When you installed Poser, it asked where you wanted the runtime. If you used the default, it would be in your documents folder. Otherwise, it will be where you told it to be.
In the content folder, you will find 4 folders, Downloads, Included, Purchases, and Runtime. Downloads is the default location if you use install from zip to add content. Included is where Poser will put the content that comes with Poser if you use the library to install it. Purchases is where things you buy at Renderosity or Posersoftware. Runtme is Your main runtime. The other three folders also contain runtimes.
ShaneNewville posted Sat, 20 April 2024 at 8:27 AM
Sunfire posted at 8:41 PM Fri, 19 April 2024 - #4483821If you're ever curious where things exist, in the Lirbary enable the Extended Details Panel (found at the bottom of library if you click the 3 dots). it will show you the filepath and it even provides a button for "Show in Explorer" to make it easier to go to. As far as I've seen it works the same for both official and custom runtime locations,I'm looking at Local Disc (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
_____________________________
My most recent Poser animation:
Previs Dummies 2
mdbruffy posted Sat, 20 April 2024 at 8:35 AM
mdbruffy posted at 8:53 PM Fri, 19 April 2024 - #4483823Found it. Thank you.Sunfire posted at 8:41 PM Fri, 19 April 2024 - #4483821If you're ever curious where things exist, in the Lirbary enable the Extended Details Panel (found at the bottom of library if you click the 3 dots). it will show you the filepath and it even provides a button for "Show in Explorer" to make it easier to go to. As far as I've seen it works the same for both official and custom runtime locations, so hopefully that will answer your question and be useful in the future.I'm looking at Local Disc (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
Afrodite-Ohki posted Sat, 20 April 2024 at 4:05 PM
You can also right-click any Library folder and click "Show in Explorer", if you're on Windows.
Feel free to call me Ohki!
mdbruffy posted Sat, 20 April 2024 at 4:56 PM
Okay. I'll try to remember all of this for next time. Thanks.You can also right-click any Library folder and click "Show in Explorer", if you're on Windows.
