Forum: New Poser Users Help
Subject: add jpg pic to prop
drawn opened this issue on May 27, 2024 ยท 7 posts
drawn posted Mon, 27 May 2024 at 4:59 PM
I have this basic scene, not rendered, of stairs, wall, 2 girls...I need to add a jpg or a pretend sign to the school wall. cut n paste didn't for me. any way?
drawn
drawn
RedPhantom posted Mon, 27 May 2024 at 6:23 PM Online Now! Site Admin
Go into the material room. Hit the edit tab. Right click on the Materials pallet. Go to new node>2d textures>image map
Now click on where the new node says none and hit browse on the new popup. Navigate to where you have your sign saved. Select it and hit open.
Now drag from that dot next to the word color to the dot next to the diffuse color on the poser surface to "plug" the node into that slot. It's also recommended to change the diffuse value to about .85.
hborre posted Mon, 27 May 2024 at 7:03 PM
The width x height of the JPG image might cause some issues when it is previewed in the scene.  You will need to match the X- and Y- scale of the square to the image and then scale the square to the right size of the figures.
nerd posted Mon, 27 May 2024 at 7:09 PM Forum Moderator
Even easier Drag n' drop the JPG (PNG, TIF, whatever) onto the material edit window. Poser will auto-create the node. All you need to do is plug it in. Done.
nerd posted Mon, 27 May 2024 at 7:12 PM Forum Moderator
P.S. Use the "One Sided Square" prop for making billboards.
hborre posted Mon, 27 May 2024 at 7:22 PM
For some reason, P13 and Win 11 do not allow drag & drop anymore.
hborre posted Mon, 27 May 2024 at 7:40 PM
Never mind, I figured out the problem.
