Uncanny_Film opened this issue on Aug 13, 2024 ยท 4 posts
Uncanny_Film posted Tue, 13 August 2024 at 5:58 PM
Hello,
I would like to know how to quickly disable each dial or all dials from setting a keyframe.
You can only do this by going into the properties of each dial and un-checking animated.
This gets extremely tedious if you have multiple objects. Is there a way to mass do this. To disable all dials from animating or Adding a keyframe.
Thanks,
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
primorge posted Wed, 14 August 2024 at 10:40 AM
Maybe with Python.
Otherwise, no way that I know of. Creating a New Master and toggling animatable in settings will record some change in the dependency listing, though no change will act in the dialed dependency... So not possible to connect settings options to a dependency.
Certain properties such as Visible and Joint Editor settings such as centers and orientation of a joint can be keyed animatable and attached to a dependency, other than that...?
I did however see something strange in ShaneNewville's post about using magnets in your other thread, a few parameters in the Other parm group that are curious. Then again I don't use magnets very often and am only a novice Poser animator, might be relevant, might not...
Y-Phil posted Thu, 15 August 2024 at 7:58 AM
I may be wrong but using Python I have found a way to get the Min/Max values, and to set them, but there wasn't any function to access the Animated boolean. One that's available is through the list of inputs of each node of each material, but I doubt that it's related in any way.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
ShaneNewville posted Fri, 16 August 2024 at 3:36 AM
_____________________________
My most recent Poser animation:
Previs Dummies 2
