drawn opened this issue on Aug 29, 2024 Β· 12 posts
drawn posted Thu, 29 August 2024 at 5:55 PM
both in preview and later in a render, important parts of the actors disappeared. I quit Poser and rebooted and started Poser and found the same problem. I changed the rendering components (cannot remember how many times) but then the problem appears to be "fixed" Hmm?
drawn
RedPhantom posted Thu, 29 August 2024 at 6:07 PM Site Admin
Are they showing in the preview?
I'm assuming they aren't set as invisible.
hborre posted Thu, 29 August 2024 at 6:28 PM
What rendering components did you change?
drawn posted Thu, 29 August 2024 at 7:16 PM
First one is a preview. Second is a render that also showed same view in preview I did not set them as invisible
hb I did not keep track of the slightly panicky settings I changed but the last that works fine is one Iβve used previously as were the ones that went bad. I donβt expect any solution this with limited info. If it ever happens again God forbid. Iβll keep better track. π€
RedPhantom posted Thu, 29 August 2024 at 8:33 PM Site Admin
First, when you load the scene, did you get a message asking you to locate anything? It might be a problem with Poser not finding the geometry for the figures.
Otherwise, check the visibility for the items either by body part.
or by body
It's also possible that the scene was corrupted. If that's the case, since this isn't the first scene that got corrupted, you might want to have your hard drive checked. It might be failing. When my drive was failing, I had a lot of corrupted scenes.
drawn posted Fri, 30 August 2024 at 3:43 PM
What happened the scenes looked fine but when I started the scan I could see the missing bodies. No early message was receivei donβt think the disk is bad cause itβs only been used for five months. I suspect I corrupted the file with my dirty talk!
Drawn
hborre posted Fri, 30 August 2024 at 4:01 PM
Don't fool yourself. I had a drive failure on a new computer months after purchase. Sectors went bad and data disappeared. Find yourself a disk manager software and run an analysis on the drive.
drawn posted Fri, 30 August 2024 at 5:17 PM
Ok good asvice
Y-Phil posted Sat, 31 August 2024 at 12:21 PM
The very best low-level analysis tool I've ever used was Spinrite. At the time, we were using it by booting on a floppy disk, but I suppose that it should be possible to put this on an USB stick. And it has received a major update recently, in order to handle correctly the most recent technology.
https://www.grc.com/sr/spinrite.htm
More infos on Youtube:
https://www.youtube.com/watch?v=Lcoa43spYRk
π«π½ππ
(γ£ββ‘β)γ£
πΏ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
πΏ Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
πΏ Nas 10TB
πΏ Poser 13 and soon 14 β€οΈ
hborre posted Sat, 31 August 2024 at 1:34 PM
Unfortunately, the OP is on a MAC OS environment. This software is useless to him.
Y-Phil posted Sat, 31 August 2024 at 4:42 PM
Spinrite is not OS dependant, the only difficulty being in accessing the OS disk, even plugged in a standard PC. But sure enough, that won't be easy, if doable, with a Mac computer...
π«π½ππ
(γ£ββ‘β)γ£
πΏ Nas 10TB
drawn posted Sat, 31 August 2024 at 6:04 PM
I believe Apple has the appropriate utility so thanks folks!
drawn
