HugePainting opened this issue on Sep 13, 2024 ยท 3 posts
HugePainting posted Fri, 13 September 2024 at 8:23 PM
Hello all! Hope you can help. I'm running Poser 13.3 on a MacBook Pro with the latest version of Sonoma. I upgraded from Poser 11 a few months ago and was enjoying Poser 13 until things went a little wonky a few weeks ago. If I change the default lights to a light set from the library, I can do it once but if I change again the entire render window goes black. No lights. I can add a light from the light control sphere. The problem only happens when I change the lights using the library
Any help/advice would be greatly appreciated!
hborre posted Fri, 13 September 2024 at 10:11 PM
How are you changing the lights in the Library? Double-clicking or check icons at the bottom of the Library?
HugePainting posted Sat, 14 September 2024 at 8:10 AM
Oh wow! I think you may have just solved my problem! I know double clicking adds lights. When I undo that add and try to change using the checkmark I get the blacked out window. Just using the checkmark from the start seems to let me change the lights no problem. Thank you!
