Forum: Carrara
Subject: Hexagon to Carrara import issue
benney opened this issue on Sep 25, 2024 ยท 5 posts
benney posted Wed, 25 September 2024 at 12:25 AM
Hi everyone. I am wondering if anyone can help with this issue between "Hexagon" and "Carrara", When I save or export a model from Hexagon as Carrara format then try to import the model into Carrara I get the following the following message "An I/O error occurred while executing import...". Yet if if I export the model from Hexagon as an obj etc then it imports into Carrara without any issues. Any help would be greatly appreciated.
WendyLuvsCatz posted Wed, 25 September 2024 at 5:20 AM
https://www.daz3d.com/forums/discussion/231316/hexagon-update-has-broken-export-to-carrara-reportedly
yeah unless you have the old crashy version as well as the update
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
benney posted Thu, 26 September 2024 at 3:35 AM
Thanks for your help with this. I am using Carrara8.5pro and the latest Hexagon. but I also have version 2 of hexagon before Daz purchased it. I tried it out and it exports to carrara just fine but the problem with version 2 is that it is missing a few helpful tools so now i have to decide do i proceed with .car or just run with the industry standard .obj. Thanks again for your help. Much appreciated.
ProPose001 posted Sat, 28 September 2024 at 8:08 AM
Seems to work for me.  Mind you I just created a primitive cube, exported as a car file, then opened the file in Carrara no errors
benney posted Sun, 29 September 2024 at 9:32 AM
I tried that and sadly it didn't work. However when i use Hexagon 2, everything works just fine. Sadly there are a lot of great tools in 2.5 which are sadly missing in ver 2. I have written a rather "LARGE" note to DAZ about this issue so we will see what they have to say in the near future.
