Forum: Community Center
Subject: High quality renders
CaesarTheGreat opened this issue on Nov 15, 2024 ยท 26 posts
CaesarTheGreat posted Fri, 15 November 2024 at 9:45 AM
Hi. I have a question about rendering images. Can i render high quality images without like 4000 series graphics card? I mean i have 1070ti now and i wonder if it's only about lighting and render settings or graphics card is mostly important? is rtx feature or other features important for render and light quality? For example could i get same result with my graphics card if i had his save file . i hope i can uplad the image.
i can't upload image so let me share link https://www.daz3d.com/stf-dforce-duskbound-for-genesis-9-and-genesis-8-female
GGreen posted Fri, 15 November 2024 at 1:40 PM
Which version of Daz Studio are you using? According the the information on the page you provided it recommends version 4.22. You can not use this product in Poser. Is this a Nvivda graphics card? How much memory does it have? Why can't you upload the image? What do you plan to do with your high quality images. What is a high quality image to you? Can you use dForce items on your computer? Some people can not use dForce. Can you use the Iray render engine? Some people can not.
Most likely you can, but depending on your hardware and the settings you use,  the time it takes to render will vary.
CaesarTheGreat posted Fri, 15 November 2024 at 2:19 PM
You ask too much. Most of them irrelevant. My question is very clear. "Most likely you can, but depending on your hardware and the settings you use,  the time it takes to render will vary."  only this sentence is answer for me. So you mean it's possible. Thanks.
GGreen posted Fri, 15 November 2024 at 6:10 PM
Well if you are not willing to provide the information requested, you may not get specific information on how to do what you want. I did  not notice those little symbols by your name when I read your question. So you are a Top Seller, Prime User, and a Vendor. I checked your store and put you on my list of vendors not to support because I was only trying to help you and your response leads me to believe you would not value me as a customer. CSR.
It has been my experience when asking a question if you provide the basic information as I requested, you are most likely to get answers that will help you including, links to why you might need to use certain settings to get the results you want.  With the right hardware and settings I can get a high quality render on my machine in less than 15 minutes, (and it can be printed) while others may render the same image and it takes 4 or 5 days to get the same results I get.
RedPhantom posted Fri, 15 November 2024 at 8:17 PM Site Admin
To be fair to ggreen, you did not give enough information in your original post to answer your question. What software are you rendering in? It's a Daz product so it's a reasonable assumption that you're rendering there, but there are bridges to other software and some people manage to get Daz products into Poser. What render engine are you using? What are the problems with your renders now? and rtx card may make your renders faster, but improve quality., it's hard to say.
CaesarTheGreat posted Sat, 16 November 2024 at 12:31 AM
GGreen posted at 6:10 PM Fri, 15 November 2024 - #4491392
I thanked you but still i thought you ask too much irrevelant question like "why can't you upload the image?" It reallly really doesn't metter dude. Seems like you got angry. You don't have to support me and i don't have to make everyone happy. That's a ridiculous threat.
After your answer I tried to design the same scene as in the image that i sent. As a result i got almost same quality image. I was just wondering whether it was possible for a professional to get the same result with a good and a bad computer. So I didn't want to waste my time if it's not possible.
CaesarTheGreat posted Sat, 16 November 2024 at 1:03 AM
RedPhantom posted at 8:17 PM Fri, 15 November 2024 - #4491394
Hi. Thanks for your answer. Yeah i use daz studio.  Actually i don't have a specific problem. I was speaking hypothetically. And yes i think rtx can make renders faster too. The images made by professionals looks very high quality and They look like they were taken in a studio sometimes. Then i try to render similar image and it doesn't look like their images. Even if i use similar hdri or same lighting system but sometimes i get much better results. Main problem is fireflies never goes away if i don't use post denoiser or noise degrain, But if i use them, this time the quality drops too much.  So  that's why i wanted to know if it's only about graphics card or am I missing something?
GGreen posted Sat, 16 November 2024 at 3:03 AM
One of the things I have learned is to render the image larger than I plan to use it, usually two to three times larger than I plan to use, then reduce it to a smaller size. If the final image is going to be 2000 x 2000 I will render it as 4000 x 4000 or  6000 x 6000 and resize it to 2000 x 2000. I use the denoise option as well. this along with the lights, and other adjustments in the render settings and parameter tabs these things make a difference for me. Using the Iray render engine. Now if I use the filament  or viewpoint render engine I make the adjustments in the filament options that I like. It depends on what you are trying to achieve. The same with 3delight or the Lux or Reality render engines.  Some people say the aspect ratio is important but that has not been something I have found to be true in my case. Lights are a key factor as well. HDRI's can make a difference, but sometimes using them can lead to longer render times.  Some people like to use lots of lights while others will say that 3 lights is usually good enough. Then there is the process of multi-layer rendering which is what I do when I have lots of lights, you can render the scene per light (can not remember the term for that). You can also set up the scene to just render certain parts of the scene and put it together in a 2D program. Rendering a scene with lots of stuff in it including lights and multiple characters can take a long time. Also rendering scene with 1k, 2k, 4k, or 8k textures can cause the render time to be extremely long. So in a nutshell there are many things we do to get the look we want. Usually it is a combination of things we have learned by trial and error. Also keep in mind that just because something works on one system it will not work the same on other systems because of the system specs.
Saying you use Daz Studio is not enough because some people are using Daz Studio 23, and some people are still using Daz Studio 10. There are some features available only in certain versions of Daz Studio. Filament for instance is not available in DS 4.21, so I was told recently. Some people are still using Window 7 or 8, and you can not use dForce on some of those system. There is also the Octane render engine that some people use. There are certain plugins some of us use,  that can not be used in all of the versions of Daz Studio.
Graphics Memory can be another issue. The more memory you have the better chance you have of being able to get the results you want, or if you do not have enough memory you will run into some problems.
Camera settings can also make a difference. Surface Tab settings make a difference. So many things contribute to you getting the result you want.
Monitor size makes a difference too. I have a 17 in monitor for my laptop, a twenty-inch pen display, and a 26 inch regular monitor that I use. Sometimes at the same time,  anything larger and the image appears to be distorted to me.  That leads me to the screen pixel size, if the pixel size is too large, I can not see the detail all that well,
To address your irrelevant comment, to me the information was reverent because of how I tend to explain things. Let say you are using a Mac, well some things are not going to work on the mac as it does on Windows. So if you state what operating system you are using, then the person reading the post will know this.
Your render settings are very important, CPU or RTX or are you trying to use both. Someone would explain why one is better than the other. Also make sure you are using the latest version of the driver for your card, or you might run into problems.
When posting a question it is helpful for us to know as much about your system as we can, and the products that you are using. Example PaperTiger has some really great hdri and cameras. One of the is the x-ray camera. I love it, the results I get with my image and the results a friend of mine gets using the same products are not the same, because our systems are different.
My comment to you that you felt is a threat was to show you how your response on these forums can affect how much people support you. When someone takes the time to contact you about something, be respectful and helpful. That is good customer service.
When I asked you why you couldn't load your image, I was going to give you some tips in that area, but ...
You can get a high quality image, but it takes a combination of things to get the result you want. You can get an image that looks good on the computer but looks crappy when it is printed. It helps to know what a person is going to do with the final image.
As for the comment about a professional, a professional what. If you take the time to learn the software you can get the results you want. There are many different ways to get the same result.
CaesarTheGreat posted Sat, 16 November 2024 at 8:31 AM
I take my hat off to your patience and interest. Sorry for the misunderstanding and thanks for sharing your experience. Im not a mean person. I just didn't understand why did you ask all of those questions before.
I heard that resizing method but i thought it doesn't work well. I only use iray render, i dont know others. But i guess best one is iray at least for daz.
Yes using many light source make things worse puting them together in another program good idea.
is it possible to reduce texture resolution on daz?
I am using the latest version. Do you think older versions have better features that last versions don't?
My graphics card memory is 8gb. I know it's not so good and using windows 10.
"""My comment to you that you felt is a threat was to show you how your response on these forums can affect how much people support you. When someone takes the time to contact you about something, be respectful and helpful. That is good customer service.""" I respect you from the beginning. I don't think it's right to judge people this way. I mean they should't judge you by your forum comments. I don't want to be seen as a vendor in forum. That's different thing, of course I am always kinder and helpful to customers. Thanks for telling me this detail though.
I don't know why but picture button just doesn't work. I used before it was working well. But i don't think we need to try to fix this.
Let me explain what does high quality image mean to me. It must be high resolution, at least 2k. Light and shadow and contrast must be perfect. Details must be seen perfecly. So i want to see an image like shot by a photographer. I never able to adjust light and shadow that way. It always look artificial and bad for me in my renders.
""As for the comment about a professional, a professional what"" I was talking about the vendors who do this job for years and make renders like a scene from a movie or photo from a real studio. If i didn't see them, i would think it's not possible with daz.
RedPhantom posted Sat, 16 November 2024 at 8:45 AM Site Admin
I don't use Daz so I can't advise on that specifically. What I can say are generalizations I've noticed with the render engines in Poser and Blender, as well as a short stint with Reality. I'm also assuming that since you're a vendor you're hoping to get the best look without postwork since that's not allowed in the MP. In my experience, you need to have high enough render settings but things like proper lighting will help also. I've never seen these things being affected by the graphics cards. The only improvement I've seen is speed so I can use more lights or higher render settings and not have it take a long time. However, I also have to say that "a long time" is subjective. Switching from an 8-core CPU to an RTX 2060 for my rending makes things much faster in my book. It drops from hours or overnight to usually about 20 to 30 minutes. And I'm happy with that. But people with an RTX 4080 or 4090 will say my renders are so slow.
RedPhantom posted Sat, 16 November 2024 at 9:01 AM Site Admin
Try uploading an image again. I just did a couple of tests and had no problem. I recommend using jpg as they seem to upload best. Just keep the compression to a minimum so you don't lose much quality. And if you get an error message, please post that and I can message the developers.
Rhia474 posted Sat, 16 November 2024 at 9:51 AM Online Now!
I'm just dropping in to say that the way you all brought back this discussion around and turned into a constructive and impactful back and forth about the topic os beautiful and exemplary and thank you for doing it!
CaesarTheGreat posted Sun, 17 November 2024 at 8:15 AM
i converted the image to png and button worked.
CaesarTheGreat posted Sun, 17 November 2024 at 8:30 AM
RedPhantom posted at 8:45 AM Sat, 16 November 2024 - #4491408
Yes i want to get the best look for my products. but i don't know what is MP. I tried your and ggreen's advices and i got better results. But yeah it takes long time. So if you this job you need at least 16 gb graphics card. Because when you increase the resolution and the amount of objects, render time is getting longer and longer. This makes it impossible to do the work. You can't even review what you've done in the viewport when you start wiewport rendering. Sometimes it's so difficult to move character's limbs. But technically you can do same renders with older pc. That was what i wanted to learn. Thank you both.
RedPhantom posted Sun, 17 November 2024 at 9:06 AM Site Admin
The MP is the Marketplace. Sorry. I got used to the abbreviation talking with the other mods. Glad we could help, even if it wasn't in a direct way.
GGreen posted Sun, 17 November 2024 at 9:49 AM
MP means market place.  Although my final renders are usually Iray, the other viewpoints allow you to move your stuff around much faster, try using the wireframe, wireshaded, wire texture shaded and texture shaded. I often switch between the viewpoints because these allow me to move things faster. If you are using a tablet with your computer, you can use the View Tab to move stuff around quickly. I also use the Tool Settings tab for this.  You can also use the Parameter tab and key in the location, I always have to estimate how far to move the items. If you are using the keyboard shortcuts, that can be a great help.In Daz Select Edit View and you should see some shortcuts to navigate around the screen.
Print outs for Keyboard shortcut links - https://shortcutworld.com/DAZ-Studio/win/DAZ-Studio_Shortcuts
https://pixelsizzle.com/daz3d-shortcuts-and-time-saving-tips/
https://pixelsizzle.com/daz3d-shortcuts-and-time-saving-tips/#daz3d-shortcuts
https://defkey.com/daz-studio-4-shortcuts
https://www.deviantart.com/peggywalters/art/DAZ-Studio-4-9-Shortcuts-614963510
https://renderguide.com/daz3d-shortcuts-time-saving-techniques/
One of the things I do when rendering is to have my renders go to a window instead of a file. Once the render looks the way I want, I save that render to a file.
The setting for this is found in your Render tab and locate the Render Target section then change it to new window. You can pull the window off to the side while it is rendering. You can still see your workspace, but you can not do anything in it until the render completes or unless you stop/cancel the render.
Here is a screen shot of a product I am currently working with - It is the Keita Far East Club and the character is her G9 male.
As you can see there are many props here. In this situation I simply click on the item I want to move, click on the parameters tab to see the settings and estimate how far to the left or right I want to move the item, then I type in the location in the X trans section or z if I am moving it forward or Y if I am moving it up. I am using the LitWire frame viewpoint. Tablet user, you can select the item using your pen and drag it to where ever you want.
You always render through a camera (this is for those that are new to Daz Studio)
GGreen posted Sun, 17 November 2024 at 10:30 PM
@CaeserTheGreat- I use this product also to help move things around a scene - https://www.daz3d.com/placeholder-manager.
This is another product you might find useful-https://www.renderosity.com/marketplace/products/125469/workflow-wizard  This is an older tutorial, but I found it very helpful. After using these products you will find it easier to do what you want in your scenes. The workflow wizard gives tips on how to get more people placed in your scene, using the claylike humans. Once you get the clay folks in position, than you can use something like the https://www.daz3d.com/alienator-pro which is useful for replacing things in a scene with other things, PropSwap is the one I use the most. Now this one-https://www.renderosity.com/marketplace/products/137789/formation-x-configuration-and-alignment-scripts-for-large-groups-in-daz-studio is very similar to the Flock-It product at the DazStore.
Another thing you can do is use low poly figures in the scene and once you have the scene set up the way you want, replace the low poly figure with your Genesis character.
There are free low-poly figures online that you can use for this purpose. I use the obj file and just import it into Daz Studio. low poly is low polygons.  I hope this gives you and others reading this post ideas on how you can move things quickly in your scenes.  Sometimes I just load primitives and apply shaders to them to use as place holders.
GGreen posted Sun, 17 November 2024 at 11:11 PM
FYI, the character sitting down in the above image is not a low poly figure.
Crystalis posted Fri, 06 December 2024 at 4:36 PM
CaesarTheGreat posted at 9:45 AM Fri, 15 November 2024 - #2989947
You can render at a smaller size, 1,000 pixels or less and then enhance the render to 4k or 8k resolutions using Topaz Labs Gigapixel AI. You don't need a special graphics card for this.
Crystalis posted Fri, 06 December 2024 at 4:58 PM
I have that program installed, if you provide me with a sample render, I'll show you what the output high resolution render is going to look like. Best of all, Gigapixel works offline as well, does not need internet. I have an integrated GPU and a quad i7 , 12-year old laptop. It takes less than 30s to enhance an image.
CaesarTheGreat posted Sat, 07 December 2024 at 7:32 AM
Crystalis posted at 4:36 PM Fri, 6 December 2024 - #4491942
I just tried and yes it works. It's not perfect but makes images much better. thank you :)
CaesarTheGreat posted Sat, 07 December 2024 at 7:43 AM
GGreen posted at 10:30 PM Sun, 17 November 2024 - #4491467
Thanks a lot. I commented two weeks ago but I guess it was not posted due to connection problems. Also i realized something, when you have a lot of morphs, the speed of moving the joints drops a lot and daz developers don't have a solution for this problem. Actaully it's a big problem. It should't scan the morphs that you don't use at that moment.  Maybe there is a script for this but i can't find anything
GGreen posted Sat, 07 December 2024 at 8:46 AM
This is why I use low poly figures in my scenes. An alternative is to create your character in a separate scene, pose the character, dress , it all everything you want in that scene and save it as a subset.  Another thing I use is  Turbo Loader https://www.daz3d.com/catalogsearch/result?q=turbo+loader
Scroll down to the bottom of the pages and you will see a video that show you how this works.
Amaranth posted Sat, 14 December 2024 at 7:02 AM
Also they moved some things around make sure you adjust these settings for better render results.
Amaranth3D
GGreen posted Sun, 15 December 2024 at 3:43 AM
Thank you Amaranth.  Always learn something new when I read these post.
