KageRyu opened this issue on Nov 16, 2024 · 2 posts
KageRyu posted Sat, 16 November 2024 at 10:34 PM
Once again there is a Daz only product showing up under the New Poser Products section:
https://www.renderosity.com/marketplace/products/166445/everyplant-red-mangrove-for-daz
It has been there several days and none of the staff seem aware. I don't know if there was a Poser version that was meant to be listed instead or not.
This version needs to be moved to the Daz Studio section.
Posting this to make marketplace staff aware so it can be fixed.
Thank You
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
abuislam posted Fri, 06 December 2024 at 6:59 AM
Thanks for bringing this up! It seems like an easy mistake to make, but definitely needs to be fixed so that it’s listed correctly under the Daz Studio section. Hopefully, the staff will address it soon. Appreciate you pointing it out!
