Forum: Community Center
Subject: My own designs on t shirts?
drawn opened this issue on Nov 20, 2024 ยท 7 posts
drawn posted Wed, 20 November 2024 at 6:51 AM
Is it possible to manually design new patterns on tee shirts so my characters willl convey any message appropriate to my story?.
drawn
hborre posted Wed, 20 November 2024 at 7:24 AM
The shirt's mesh should have a UV template associated with it which is normally found within the object file.  If such a template does not separately exist, you might need to rely on a third-party app to unwrap the object file and save the template as a .jpg file.  The .jpg image will need to be opened in another third-party graphics program so you may place and center the design of your choice.  It is best that you have a high-resolution image or text for it to be legible in the final render.
hborre posted Wed, 20 November 2024 at 7:48 AM
Another simpler alternative is to locate the texture file for the shirt and open it in a third-party graphic program.  Create the design in a separate layer and position it exactly where you want it.  Merge the layers and save the image as a .jpg or .png file under a different name.  In Poser, replace the original texture file with the one you created.
A_Sunbeam posted Fri, 22 November 2024 at 2:37 AM
My son goes to redbubble to get his designs printed on t-shirts etc.
hborre posted Fri, 22 November 2024 at 9:21 AM
You're kidding?
A_Sunbeam posted Sat, 23 November 2024 at 2:12 AM
hborre posted at 9:21 AM Fri, 22 November 2024 - #4491565
You're kidding?
No. Sorry, misread your post, thought you were looking for an outlet. Please ignore.
abuislam posted Wed, 04 December 2024 at 4:33 AM
Yes, you can manually design patterns on t-shirts to convey your story by using graphic design software or custom printing services. You can incorporate your characters and messages as you see fit!
