Corinna opened this issue on Dec 05, 2024 ยท 4 posts
Corinna posted Thu, 05 December 2024 at 7:02 AM
I have a problem with my purchased lights. Now when I double-click to use one from the library, the previous one remains. Normally, the previous light is replaced when I click on it.
This was not the case with the previous Poser.
What can I do to make the light overwrite the previous light and not overlay it?
It is really time-consuming to delete all the lights every time, which only works manually.
I am very grateful for any help!
Corinna
kbdm257 posted Thu, 05 December 2024 at 8:43 AM
In the library where your lights are, click once the light you want to highlight it. At the bottom there's a single and a double check mark.
The double check mark adds the lights to the scene without removing the lights already in the scene and the single check mark replaces the lights in your scene.
DeeceyArt posted Thu, 05 December 2024 at 8:54 AM
You may have inadvertently changed your double-click behavior.
Open the General Preferences dialog. Select the Library tab. The first option on the left is double-click behavior, choices are Add to Scene or Replace Existing.
Corinna posted Thu, 05 December 2024 at 9:32 AM
I thank you both from the bottom of my heart. Both options worked. This means I can carry on posing without much effort.
Thank you very much!!
