Jin_Yindao opened this issue on Dec 21, 2024 ยท 9 posts
Jin_Yindao posted Sat, 21 December 2024 at 4:04 PM
I cannot find the keyboard or mouse shortcuts for panning the camera. Can someone tell me what they are? I have all the rest set.
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
Richard60 posted Sat, 21 December 2024 at 7:50 PM
There are no keyboard shortcuts. If you go to Edit-->General Preferences-->Interface there you will find all the possible things to assign a keyboard key to activate the command. There are no camera movements listed. You can select a particular camera, but not control the movement of that camera via the keyboard. You can use the mouse on either the Camera Control ball in that window OR use the mini ball in the upper right corner of the Poser window. Either of those will move the current camera view around. The most likely reason there are no keyboard shortcuts is that the Current View Camera and the camera selected via the Parameters control panel are not the same. You can have the View camera set to Top (looking down on the scene) and have the main camera selected in the parameters palette and the controls will move the Main Camera which you can watch from the Top View to put it where you want. So unless you select both the View camera and the Parameters for that camera then the movements you make with the dials won't be visible until you switch views
Jin_Yindao posted Sat, 21 December 2024 at 9:47 PM
Y-Phil posted Sun, 22 December 2024 at 9:33 AM
Mouse left click, don't release, press the space bar, move your mouse. Works on Win & Mac. I think that's pretty much like Ph0t0sh0p and almost like Gimp.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
Richard60 posted Sun, 22 December 2024 at 11:19 AM
Slight update to what Y-Phil said is press Spacebar first then left click and move. The other way around does not do anything.
Y-Phil posted Sun, 22 December 2024 at 1:39 PM
Oopsies, thank you Richard
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
nerd posted Sun, 22 December 2024 at 2:27 PM Forum Moderator
Should mention too that [Alt]+Left Drag will rotate the camera. Scroll wheel will dolly in/out
ShaneNewville posted Fri, 31 January 2025 at 1:07 AM
idk if animation is your thing, but in my experience here are a few tips on how to speed up your navigation in general:I cannot find the keyboard or mouse shortcuts for panning the camera. Can someone tell me what they are? I have all the rest set.
_____________________________
My most recent Poser animation:
Previs Dummies 2
nerd posted Fri, 31 January 2025 at 3:19 PM Forum Moderator
... An then get a Space Mouse for navigating the scene. Just know that once you start using a Space Mouse any app that doesn't support the it will seem antiquated and awkward.
Poser has supported these things since Poser 6 ... https://3dconnexion.com/us/spacemouse/
