RAMWorks opened this issue on Dec 24, 2024 ยท 4 posts
RAMWorks posted Tue, 24 December 2024 at 12:52 PM
Since ZBrush uses Cinema 4D scaling I just need to know how to set the the importer to the correct scale to get a fit morph I made in ZBrush. Weirdly, in Poser 13, I did all this work in ZBrush and used the bridge and it's like the morph came in with no geometry modifications so I decided to export from ZBrush to a folder and want to see if it makes a difference and actually works as it should.
Once I get that done then I need to try to find my notes to manually hook up the morph for the clothing figure to follow when I have the figures FBM activated.
Thanks for the help
Richard
---Wolff On The Prowl---
HartyBart posted Wed, 25 December 2024 at 6:04 AM
There was a PoserScaler for ZBrush plugin from ZBrushCentral, circa 2009. But I can't find it now. Seems to have gone. Possibly it only worked with earlier version of ZBrush?
Possibly helpful, from a ZBrush forum... "When I import an OBJ through PoserScalerPlugin with 100 and I go to the Export Menu there is a Scaling Factor written 34.126045".
RAMWorks posted Wed, 25 December 2024 at 9:57 AM
OH, thank you, that might work. Not sure if I can set the scaling in Poser to such an odd number but it's worth a try!
RAMWorks posted Mon, 30 December 2024 at 12:17 PM
So from C4 to Poser it's closer to use this scale: 41.0
