atpo opened this issue on Feb 15, 2025 ยท 4 posts
atpo posted Sat, 15 February 2025 at 6:28 PM
Excuse me!
Do model ,then mark seam for uv unwarpped, but does it need to clear seam after uv unwrapped?
I oftern do not clear seam then export as obj.
Thanks.
Lobo3433 posted Sun, 16 February 2025 at 9:10 AM Forum Moderator
Once you mark a seam for UV unwrap you do not clear a seam unless you are going to reUV unwrap because it did not unwrap the way you wanted it that would be the only reason I would understand as to why you would clear a seam.
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
Warlock279 posted Sun, 16 February 2025 at 5:25 PM
As Lobo said, there shouldn't be any need to clear the seams before export. The seam information is stored as .blend information, and isn't carried to .obj point data so far as I'm aware. Additionally the seam doesn't split/un-weld geometry either so there shouldn't be any reason to worry about it.
Core i7 950@3.02GHz | 12GB Corsair Dominator Ram@1600mHz | 2GB Geforce GTX 660
Lightwave | Blender | Marmoset | GIMP | Krita
atpo posted Mon, 17 February 2025 at 11:37 PM
Thanks.
