Binx opened this issue on May 19, 2001 ยท 7 posts
Binx posted Sat, 19 May 2001 at 1:50 PM
Attached Link: http://www.geocities.com/netreaper2001
I have developed a figure and I want to save her face as a morph target for another p4 female...What do I do to easily transfer the face? Thanx for your time.... Binxangola posted Sat, 19 May 2001 at 5:09 PM
The only way I know is with Morph Manager. You can find it... I don't know where you can find it! ...!?#@$ Ask anybody, they'll tell you (anybody but me). Basically select the face you want to create and hit Create morph target. Save the poser file and open MM, then follow the instructions. It's easy peasy honest! Sorry about the link.
stu-art posted Sat, 19 May 2001 at 5:18 PM
hello Binx, all you need to do is save the character as a pz3 or pz4 file in your docs or wherever convert them to a CR2 and use morph manager 4 to group them into a single morph target i will tell you where to get everything and show you how sunday i will also clue you into some other funky stuff if you like
Anthony Appleyard posted Sat, 19 May 2001 at 5:53 PM
Hasnt Poser 4.0.2 & -.3 got an option to export to .OBJ in morph target mode?
Eowyn posted Sat, 19 May 2001 at 6:02 PM
4.0.3 does at least... So if it's a face morph, you could just export her head as a morph target :)
GrayMare posted Sat, 19 May 2001 at 8:15 PM
Go to File/Export/export as wavefront obj. Select only the "head", click OK or next or whatever... it asks what to name it and where to save it. Then you get a dialog box asking what options to use to save it. Deselect everything but "Save as Morph Target, no world deformations" or something like that. Click OK, and you're done. Remember you'll get anything you've done to the head, so remove anything you don't want to bring with the morph--smiles, sticking out tongue, whatever. When you add the .obj file you created as a morph target, and set it to "1", you'll have your face. Before adding the MT, set all other morphs to "0" or the face will look funny. This is important on V2, cause she's got some pre-set morphs that will make faces really funny. GrayMare
stu-art posted Sun, 20 May 2001 at 5:42 PM
hello again, morph manager 4 is at 3d commue.com poser freestuff utilities to save your character as a morph target add it to your libraries new figures poser will save it as a cr2 file quit poser and load MM4 load your charactres cr2 file click on head on the list of body parts click on morph targets select all of the mts that you used right click and use the combine all mts option hope this helps
