bryan opened this issue on May 20, 2001 ยท 5 posts
bryan posted Sun, 20 May 2001 at 7:54 PM
hi im trying to render in cartoon shadding is that posible in poser, i have seen some good stuf on the daz site but don't know how they do it, i tryed the sketch desiner but it comes out to messy, is there another way, or are they using another program
the3dwizard posted Sun, 20 May 2001 at 9:11 PM
Don put some comic style sketch render presets in the freestuff. I haven't tried them, but you might. Just search for Don in the freestuff.
Varian posted Sun, 20 May 2001 at 10:42 PM
While you have cartoon shading set as the display preference, just grab a screen capture of your scene. You can enlarge the display window to however much room you have on the desktop. That's the limitation of doing it this way. :)
Orb posted Mon, 21 May 2001 at 2:03 AM
What you can do is this, and sorry if I don't explain it well ... I have just started playing with this idea myself, because I wanted to do some cartoon style renders. Set up an animation to the size you want and be sure it only has one frame in it. Set your preview window to the cartoon style. Choose Make Movie, select Sequence type: image files, Resolution: full, and Quality: Current Display settings ... and tick the antialias button. Then it will make one image for the one frame in cartoon style and antialiased. I believe there are some limitations on what size it can be, but I am not sure yet, as I haven't played with it much. Hope that helps! Orb
Don posted Mon, 21 May 2001 at 2:29 AM
Attached Link: http://Cyber-Fyber.bbay.com
