Forum: Poser Technical
Subject: metarial knowlege
fablue opened this issue on May 28, 2001 ยท 4 posts
fablue posted Mon, 28 May 2001 at 8:52 AM
is anyone know that how can i delete the metarial list in poser or else let say when assign a knew metarial and if you wanna remove it what should have been done ? oh im using mac and poser 4 thanks
ScottA posted Mon, 28 May 2001 at 12:27 PM
Poser reads the materials that are listed in the .obj file. Then writes them into the figure's .cr2 file. You can use the MAC version of UVmapper to change the name of the material easy enough. But you'll still have the old material in your list in Poser unless you manually remove it somehow. Us PC users use CR2edit for that. But you could open your .cr2 file with a text editor and remove the materials with that. ScottA
fablue posted Mon, 28 May 2001 at 3:42 PM
thanks scottA is anyone help which text editor should i use for mac
JKeller posted Mon, 28 May 2001 at 4:28 PM
I would suggest BBEdit.
