dgroncki opened this issue on May 29, 2001 ยท 8 posts
dgroncki posted Tue, 29 May 2001 at 11:16 AM
Hi All! I'm new to Poser and want to use it to create game models if possible. Is there any conversion path from a poser model with animation into ultimately an animated .x format? I realize Poser doesn't export to .x itself, but perhaps if other tools sat in the middle to do some conversions, maybe the end result wouldn't be too bad? In leiu of the animated features, how 'bout just into (non-animated) .x format? (or .md2 format?) thanks.
Mason posted Tue, 29 May 2001 at 11:18 AM
There is a tool that coms with the direct X sdk that converts from 3ds to x. Maybe that will help.
Darian posted Tue, 29 May 2001 at 11:40 AM
Attached Link: http://www.xdsoft.com/explorer/
3D Exploration by Xdimension exports in .x format. Theoretically, should be able to export from poser to .obj, open in 3D Exploration and then export to .x. There is a free, fully featured 30 day trial version available on thier website. Good luck.Deimos posted Tue, 29 May 2001 at 1:09 PM
Is there any way to export poser animation ie. frame 1-30 along with the model and have that imported into either direct X or Open GL? Thanks. Deimos.
Cheers posted Tue, 29 May 2001 at 2:33 PM
Don't forget that you will not be able to distribute the game if it contains default Poser or DAZ model geometry....even if it is contained in an .X file. Cheers
Twitter: Follow @the3dscene
dgroncki posted Tue, 29 May 2001 at 2:53 PM
How much morphing or modifying is required before you COULD distribute a .x model which started out based on a Poser default?
daeve posted Tue, 29 May 2001 at 3:05 PM
Attached Link: http://www.righthemisphere.com
3d Exploration is now owned by Right Hemisphere, the makers of Deep Paint 3D. DaeveDogface posted Tue, 29 May 2001 at 9:29 PM
By the terms of the legal statements, essentially, no amount of morphing or modification of figures included with Poser or from DAZ will be sufficient. You have to start with a new geometry entirely.
