Subject: Problem with Poser
ledenko opened this issue on May 31, 2001 ยท 4 posts
ledenko posted Thu, 31 May 2001 at 3:13 PM
Sometimes (actually every time), when I work with, let's say Vicky 2 and I use Victoria 1 clothes on her i get an error: Caught C Exception: exception access_violation etc... Could this be memory related as I only have 32 megs of RAM...
JeffH posted Thu, 31 May 2001 at 3:55 PM
Attached Link: http://www.curiouslabs.com
Yes it could. Do you have the Poser4.03 patch installed? If not, you can get it at www.curiouslabs.com -JH.
ledenko posted Thu, 31 May 2001 at 4:00 PM
No, I don't but will install it now... Actually, I have to reinstall Poser because it crashed permanently :)
ravenfeeder posted Thu, 31 May 2001 at 7:05 PM
I don't see how you did anything much with only 32 megs of ram. I have 288 megs installed and I still at times run into problems when I've created a scene with a lot of 'pieces'. You can use virtual memory, if you have the disc space, but that slows things down a bit sometimes
