bb2000dk opened this issue on Jun 01, 2001 ยท 6 posts
bb2000dk posted Fri, 01 June 2001 at 12:51 PM
Does anybody knows how to attached wallbricks to props. With only few bricks I need to tile them to fit wall. Thanks for helping
JeffH posted Fri, 01 June 2001 at 2:54 PM
I think there's a trick you can do with UVmapper to get an OBJ to tile the texture. The thread is in here somewhere, I'll have to hunt it down.
igohigh posted Fri, 01 June 2001 at 2:55 PM
Normally a "Brick Wall" would be done in Poser with a solid flat obj and the brick "texturing" is created using a BUMP map. To tile separate brick objects you are in for a HUGE file!
JeffH posted Fri, 01 June 2001 at 3:06 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=129657
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=129657Lovely Lady posted Fri, 01 June 2001 at 3:46 PM
This is what Steve posted at the Poserforum a while back for the tile trick in UVMapper. I saved it. Okay, you're mapping a WALL So this should work. Open the prop in UVMapper from an OBJ file Select the geometries then EDIT/NEW UVMAP/PLANAR In the dialog box select DON'T SPLIT. The map should probably be allong the Z Axis as well. Hit OKAY. Hit the * key. Once, to tile 4 times. Twice to tile 16 times. Hit the HOME Key (why is unimportant, just do it) Hit ENTER Now go to File/SAVE MODEL Save the model, and import into poser.
BillyGoat posted Fri, 01 June 2001 at 9:22 PM
THANK YOU! I've been going nuts with the same problem. No matter how big I make the 'brick wall texture' it still stretches like mad. I'm talking a 6 meg sized textures...
